Fault / coil light under high load
Hi,
earlier when accelerating fairly hard the car went into what I assume was limp mode with the coil symbol flashing on the dash. After a while of the engine off it started and drove ok (wouldn’t pull off straight away as no power).
I know there is a blow on the flexi of the exhaust so I guess lack of back pressure and I noticed that there was a bit of smoke coming out of the PCV valve. Is it likely linked to one or both of these?
What engine?
Sorry 1.6tdi 105bhp in a 2010
Most likely to be an injector fault, there will be fault codes stored, tell us what they are.
