Washer jets stopped working!!
Hi fellas, recently went on holiday for two weeks and left car at the airport. Upon returning the washer jets front and rear have stopped working. When I try to use them nothing happens, no sound of the motor trying to work. Checked the fuse and that is ok and there is definitely water in the reservoir. The same thing happened in the summer when I went on holiday but they started working after a couple of days. Any suggestions on what the issue could be? Thanks
It’s a 2.0 diesel vrs blackline btw
Wait a couple of days!
Maybe try and get a small pin and try to clean the washer jet nozzle.
I had an issue with my Mk2 Octavia where the rear washer jet got blocked (common problem) used pin to clean nozzle and worked fine afterwards.
You can access it by taking off the rear plastic cap on the wiper arm and then you have access to the nozzle which can be easily taken off.
For the front nozzles I'm not sure how to fix them as I've never had any issues with them but I'm sure you can try the same pin method to clean them.
