Sound changing to ‘voice/phone mode’ after driving for a minute or so when using CarPlay.
So I have a strange issue and I’m wondering if anyone has experienced the same or has any insight how I can solve this.
So when I start my car, plug in my iPhone to start carplay, start driving - after about a minute the audio channel changes from the music setting to the voice setting (usually pops up when I’m on the phone, using Siri etc)
The only way I have found to get it back to music mode is activate Siri and then cancel. I haven’t a clue why this could be happening, would be grateful for any insight!
 This may or may not help you but you seem to be experiencing changes to your computer settings which happen on their own without you doing anything. Is that correct? I had a problem with my 2i plate  Fabia estate some time ago where the central  display was showing driving data and of its own accord the display changed to other settings. These included connect phone and infotainment system switched off.  I  raised it with the workshop and they did an update that so far anyway has sorted it. This problem  started in early August and happened 5 or 6 times and the update was done just over two weeks ago.
      I know this isnt exactly the same issue as you are posting about but the common thread is settings are changing for you without any action on your part as they did with me. Is it worth asking the dealership if they have an update for your issue?
       Hope this helps.
 This is further to my response of last Thursday. I should have added that my post on Briskoda that I referred to  was dated July 29th and it started with the words I need help....
    Thanks.
