2,0 tdi Scout run for 1 sec
When the car is cold and I try to start it, it run for 1 sec and then dies. I need to try 10 times before it starts. I also need some gas. It can rev up to 2000 rpm and then die.
If you then drive it a short period of time and stops the car it can behave the same. So I dont think it has something to do with fuel going back to the tank. After ut starts it runa normal.
I have replaced the glow plugs and dieselfilter. No fault codes.
Some ideas?
Any ideas?
You don't give your engine code but I remember a thread on here about confusion on which fuel filter to fit. There were two type/makes, one of which caused something similar if I remember correctly.
Do a google search using this forum as the first search terms followed by your own query.
Perhaps this reply will jog the memory of others.
