Fault code P2563
Hi guys, I started my car and the coil light was flashing. I’ve got home and plugged it in and it’s come up with the code P2563. I’ve googled it and it says about the vanes for the turbocharger? Has anyone had any issues with this? A mate has told me Mr muscle cleaner helps? Thanks
D4074A2A-E158-40D1-8B30-2221AA1803F0.thumb.jpeg.fc540e2d0b4cb6c60d92774b97fefe50.jpegdo you mean this code as I’ve got the exact same one 🤣🤣. I too am thinking Mr muscle but need to see if there’s an entry point to the back of the turbo, on quick look I’m thinking I may need to remove the DPF section to gain access from there but maybe/hopefully there’s another option
Hahah yeah that’s the code I’ve got, not got a clue what I’m doing with cars so I’ve not attempted anything yet. But the coil light hasn’t flashed since I’ve posted and not had any problems I’ve noticed since?
I’ve bought a new egr boost control valve as it was only £60 and gunna fit that and see if that helps,, then I’m going to take it to a garage and see if they have VCDS and check my DPF is ok (I suspect not) and get any other codes and maybe try to regenerate the DPF (other issues I’m having I think)
but yeah mr muscle and egr replacement possibly next
