3 bleeps at 64mph
Hope you can help please l have 3 bleeps sounding at 64mph this is not the speed warning which is switched off.
19 plate Karoq 1.5SE
any suggestions how to turn it  off would be appreciated.
thanks
Have you set the winter tyres speed warning perhaps.
Don’t know about this,  l will check the handbook but there is no mention of this on the menu thanks
Not the winter tyre speed setting this is turned off thanks
Cars have stupid software that can have bugs, it might be an idea to turn on the winter tyre warning and a speed warning if visible, then lock car.
Wait 1 minute, and then unlock and turn off the features, then next time you hit 64mph, you can see if it has stopped.
Unless someone else knows what these 3x beeps could be?
I had an issue with my own car unlocking ALL doors when you unlock, despite it being set to single driver door only, once I changed settings to unlock all/then back to single door it then saved it.
Does the issue happen with both of your keys?
I will try that but tried most combinations including the factory reset with no success. I am sure the main dealer could fix it but expensive at their labour charge
@BroadsrangerHas this just started as something new now?
Instead of turning off the Speed Warning maybe set the Winter Tyre warning at 100 MPH and the other at 110 and see how that goes.
Ask a Salesperson for assistance to reset or stop the warning if needs must.
Is the car out of warranty now?
Edited by roottoot
🤔interestingly 64mph  is 100 kph will try your suggestion and🤞thanks
@BroadsrangerI alerted a Mod so that your thread can go to the Karoq section.
Is the car new to you?
16 minutes ago, Broadsranger said:
🤔interestingly 64mph  is 100 kph...
Nearly. 100kph = 62.1mph.
Gaz
@Gazthat indicated 64 mph will be pretty much the car doing 62 mph then if the GPS was checking it.
Maybe it is a setting someplace on that screen.
I have had the car 2 years now bought with just 1k on the clock in lockdown so didn’t get driven much over 60mph for several months (retired and living in Norfolk - no motorways) so well out of guarantee regarding any remedy from the dealer.
Have you tried 2nd key to see if it occurs with that one?
There's only a few stretches on the A47 that are dual as you know, so at least you can test it out without leaving Norfolk.
