Variable boot floor question
Hey all
Thinking of buying a Mk3 VRS estate facelift.  Does anyone know if the VBF from a MK3 estate (2014) pre facelift go straight into the newer model? 🤔
Thanks in advance
Don't see why not! as far as I'm aware the Load Space in both wagons are the same (facelift stuff was body mainly)! it's just Skirts and Cabin stuff (and performance tweaks of Corse) !
Edited by Simoneale1973
Ok, can confirm that is does fit. The facelift model doesn't have the clips and the runners for install but no drama as I can easily knock something up
The side panels and rear most panel are completely different so you would have to change a fair bit to get it to fit.
