Calliper repair kit
Hi I have skoda octavia scout 2010
Calliper needs replacing so I thought I would buy a piston repair kit 38mm
Put in my car details a kit come up on amazon bought it but rubber boot that goes over the piston has a small steel ring in it the original one.
The replacement I have does not have a ring in it and is 4mm smaller in diameter than the original
So will not be a tight fit in the housing
Any one else had this issue looks like I might have to buy the whole unit to be sure
It sounds like you bought the wrong parts.
If you're taking the calliper apart you could just disassemble EVERYTHING, THOROUGHLY clean in hot soapy water, hot rinse and hair dryer dry.
Provided there isn't significant pitting on the piston or obvious wear/leaking from either the piston seal or handbrake mechanism o-ring you should be good to reuse.
Edited by MicMac
The piston isn't to bad and there was no leaking it was sticking there is a slight ring around the piston ovs we're it must ov been sticking
The piston boot was split so I have pulled that out thats wy I bought this kit
Now don't have a boot replacement
But the seal was good around the piston was ok
