Where is the MAP sensor,Skoda 1.4 16V 2003
I have a 2003 Skoda1.4 16V car and I couldn't find the location of the MAP sensor on the engine. Can someone help me?
Edited by cheezemonkhai
English from post below.
Sorry, I think I didn't write in English. I have a 2003 Skoda 1.4 16V car and I couldn't find the location of the MAP sensor on the engine. Can someone help me
Yes, it's fitted to the intake plenum low down on the left near the dipstick, it's not easy to get at and they don't give any trouble so I'd look for air leaks in the vacuum servo pipe first if I were you.
EPC and engine lights sometimes come on in the vehicle and when I connect the vehicle to the computer, I get the error codes P0106 and P0170. I think they are related to the MAP sensor and the throttle. That's why I wondered where the MAP sensor was.
Far more likely to be an air leak, the codes are just telling you the ECU doesn't like the amount of uncontrolled air entering the engine.
Please note - I am not a mechanic or expert in anything.
Remember the computer program is a diagnostic tool so most times you have to use the information given rather than taking it as an absolute answer.  Look up the codes and see what is common to them as a starting point from the codes and how they might relate to each other.
P0170 VW - https://www.engine-codes.com/p0170_volkswagen.html
P0106 - https://www.engine-codes.com/p0106.html
Edited by nta16
