Ventilation & Climate problems (Pannes de Climatisations) SKODA FABIA VRS 130
Bonjour !!!
je possède un SKODA FABIA VRS 130 Année 2007
La clim est en panne, quand je mets en marche il y
a que le ventilateur intérieur qui fonctionne et les
ventilateur dans le compartiment moteur ne fonctionne
pas ,les fusibles sont ok ,et le compresseur ne fonctionne pas
pas.
prévoyez-vous m'aider ?
Merci d'avance
Edited by cheezemonkhai
En anglais sil vous plait!
Approximate translation is that the poster has a 2007 Fabia vRS 130.
They need help as their climate no longer works.
Motor does not work to ventilate the car.
The fuse is not blown, the compressor does not function.
Could you offer assistance please and thanks in advance.
@fvincent974
Forum rules do ask that all posts are in English, so if you would be so kind to edit your post to English or post what exactly you’d like said and a moderator can update the first post.
In terms of the issue, does you fabia have selectable AC with manual switches or full automatic climatronic where you just set the temperature and it does the rest?
  • Monkhai changed the title to Ventilation & Climate problems (Pannes de Climatisations) SKODA FABIA VRS 130
If it's a Mk1 it'll be manual climate control.
@fvincent974 - try turning it on to the setting marked '4' to see if it works, it may be the resistor pack. Otherwise, the fan in the HVAC system will be kaput, I reckon.
Cheers; I wasn't even dead certain what language that was. Even if I presumed French, is it French French, Swiss French or Walloon?
Something was wrong with the "prévoyez-vous m'aider ", either an auto-correct error or maybe it's the way the Wallons, Ontariens or Québecoises say it as it reads "do you forsee helping me?"
