Error Code 01134 Just Disconnect Alarm
Hi,
I trust someone can help.
I have this error "01134 - Alarm horn Lower limit not reached"
From what I have read it is because the battery in the alarm has low voltage so unit needs replacing.
At the moment whenever we lock the car the alarm goes off so have to leave the car unlocked.
Can I just disconnect and remove alarm while I work on getting this fixed?  Will this cause any other problems?
Any help/comments gratefully received.
PS the car is a 2012 Octavia Mk2 1.6 TDI
  • Sponsor
Yes, if you know where to physically find it. It won't cause any other problems, I don't think.
There may be a specific fuse you could remove as an alternative, I can look up which one if you like?
Hi Pete,
Many thanks for quick reply.  It appears you are correct that removing the alarm is OK and does not cause problems.
This afternoon I decided to remove the alarm. Not too difficult.  It is under the wheel arch trim on RHS of car behind the front wheel.
After removing the alarm all seems good.  I don't get any warning lights and now can lock the car.
I will investigate getting a replacement (or replacing the internal battery) or maybe leave it as it is.
