A little advice please!
Hi
New Skoda owner alert!
I've recently bought a 2011 Roomster (Auto) and there's no manual!
The indicators don't make the usual ticktock sound when in use and if I leave the headlights on by accident, there's no warning beep.
Is this something that can be fixed?
Are the headlights meant to be automatic and I'm missing something?
One last thing, does the car have a RAID function?
Thanks in advance!
23 hours ago, EmmaWil said:
there's no manual!
Try on the link above.
Thanks, AG Falco
What is RAID?
15 minutes ago, 26DIPP said:
What is RAID?
It's where the doors lock once the car reaches x mph
You can set that in the MFD or with VCDS.
What are they?
Please note - I am not a mechanic or expert in anything.
@EmmaWil if you don't have the paper printed copy of the Owner's Manual you can get a pdf of it from the following link using your VIN, on your V5C keeper's paper and other paperwork and on the vehicle or look for the (part) year (it was built). - https://manual.skoda-auto.com/004/en-com/Models
ETA: if you read the Owner's Manual before or at the start of vehicle ownership and refer to it when required you will know more about your vehicle than many long term owners.
Edited by nta16
ETA:
Ooo ta very much!
50 minutes ago, EmmaWil said:
What are they?
MFD is the Multi Function Display on the dashboard
VCDS is a computer program and associated cable for reading faults on the car and changing settings. https://www.ross-tech.com/vag-com/
