This weekend I will be mainly....................
1 - changing Glow Plug 4, OBD 11 came up with cct fault, new NGK heater arriving today so when off shift that's No. 1 job, any known trip hazards?
2 - Coolant pump C stuck, OBD 11 again, see the threads detailing check for connector corrosion / wire breaks, but any idea of a part number as looking at eurocarparts / GSF can't seem to accurately find this electrical pump C!
3 - Estate - water in the spare wheel well - thought I'd sussed it after having the tow bar fitted and using silicon sealant around the cable grommit, but still getting water collecting! Did check with a hose pipe around the door seals but nowt seen, any thoughts on ingress points?
TIA
Snowy
Do you have a sunroof?
no sun roof, cant see any tracking stains so have a feeling it might be just when it's moving
I’m sure I’ve read water usually comes in from light cluster or the boot seal itself.
Cant remember reading if the light cluster has a replaceable external gasket or just taking it off and cleaning it is the fix
Good luck on your investigations.
I'll be "mostly eating blancmange"
