Electric tailgate issue - understanding fault code
Hello, first post after i was recommended this site by a friend.
I have a 2017 VRS estate and currently have an issue with the power tailgate.
Just before Christmas my other half, who rarely drives the car, opened the tailgate by manually lifting it. This caused it to stop a third of the way up and it kept beeping.
I have tried the reset procedure which doesnt work, the tailgate unlocks but wont open however it will close when pressing the button.
When closing it sounds like one or both of the motors are stuggling.
A friend has plugged it in to VCDS? which gives the attached fault information.
The date and time is exactly when the tailgate was forced open.
I am assuming one of the struts needs replacing however i would rather not change both unless i have to as they arent cheap.
Does anyone know which side is motor 1, or could this fault code indicate another problem?
Thanks in advance
Motor 1 is the left strut normally.
Unplug it and see if you get a fault code for motor 1 open circuit.
Personally i think get a pair, you can get aftermarket ones on ebay for £220 a pair. Please make sure to calibrate them after they are fitted.
Thanks for the prompt response.
I will give that a try. £220 is a lot better than nearly £300 per side on Autodoc
If you need a hand with part numbers, PM me and i can help supply exactly what is required.
