Replace Rear seat belt "socket"
Hi, due to sell the beloved 17 plate skoda superb this week and taking out the dog's seat belt it gets jammed....after a bit of "wiggling" the button has shattered....have looked into replacing to be quoted the whole seat belt unit has to be replaced and the part is £276.24 then £230 labour...
I've tried every way of explaining that it's "just the button" but two main dealers are saying it's definitely the whole unit that needs doing.
i appreciate it's an MOT fail and safety issue which is why I don't want to mess on with it or glue it
waiting on 2 independent garages to come back with quotes but can anyone confirm it's the whole seat belt unit that needs replacing at all?
thanks in advance
It has to be a new belt, if you broke the double-socket you would have been able to buy separately.
cheers buddy. very much appreciated.
typical!
i don't suppose you have the part number at all?
Thanks again
Edited by mattjames1980
I cannot give an accurate part number, you need VIN decoded results.
no worries mate, appreciate the replies. have a good one!
It’s always typical when I do a dump run that the bits people need are what I’ve just thrown.
Yes it comes complete with the seatbelt as they are riveted together sadly.
your best bet would be a breakers yard and just drill the rivet out and replace it - would be a whole lot cheaper.
(rivet is just for locating and doesn’t actually secure the belt buckle, if it was safety related I wouldn’t recommend it)
