Head Unit Shenanigans
4 minutes ago, pab567 said:
Hold your horses. x is not for region but for version - the higher is better. 3T0035681x is also fine. I recommend the units on software 6270 or 6276 as these are so called C14 versions, with more powerful processor, more memory, SSD instead of HDD and more effective GPS chipset.
I've found one that ends in a K. I'm assuming that's the one to go for.
3T0035680K? This should be slightly older unit, version C12, still with HDD.
Ok cool. Who knew this was so complicated haha.
The most affordable one for me rn in a 3T0035680C. From what I can tell K is the highest it goes anyway. So maybe this version never got that upgrade.
Most of the 3T0035686x ones also appear to be on a lower SW version than you said was SSD. This seems to have been a much later change.
So long as 3T0035680C will work and can have the 2020 map pack installed. Im happy to go without DAB and an SSD for the sake of saving me over £300!!!
Quite an old version, recommend yto update SW to 5238 when you get it
Was going to do that.
Also update the maps to V17. Dont know if you know where I can get the ISO before I spend money on a disk.
Check your PM :)
Hi, all.
Where can I update my SW and my Maps & Speed Cameras for my Columbus RNS510, please?
Many thanks in advance!
46 minutes ago, Xande007 said:
Hi, all.
You should be able to find the SW online, but I don't think you can update yours any further anyway.
As far as maps and cameras go you need a disc, I have one but ended up not needing it as mine was already up to date.
It requires a dual layer DVD but I may be able to send you an ISO file, or you can buy them cheap online.
Many thanks!
Is your DVD disc the actual original V17 disc, please?
Is the ISO file from the V17 disc version, please?
Thanks in advance!
27 minutes ago, Xande007 said:
Many thanks!
Thanks in advance!
Yes I have the V17 disc
OK!  Please let me know if you are willing to sell it or give it away.  Thanks in advance!
Hi again,
I'm wondering if you know if the LATEST software version for my unit is indeed SW 6276, please?
Many thanks in advance again.
