How to solve problems,
I recently bought a skoda. It's a log file vcds. How do I solve these shortcomings? There aren't many. But I don't want it to be any!!
Spoiler
Chassis Type: NU-SK37 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 6D
          75 A5 BB BC D6 D7
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
4B-Multifunc. Module -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
75-Telematics -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
D6-Light Ctrl Left 2 -- Status: Not registered 0011
D7-Light Ctrl Right 2 -- Status: Not registered 0011
Address 01: Engine (J623-DGTE)       Labels: None
   Part No SW: 04L 906 056 TG    HW: 04L 907 445 G
   Component: R4 1.6l TDI   H01 7226
   Revision: 22102001
   Coding: 01254032436405093000
   Shop #: WSC 00040 790 00001
   ASAM Dataset: EV_ECM16TDI03004L906056TG 004002
   ROD: EV_ECM16TDI03004L906056HJ.rod
   VCID: 0557910925A2D8F3D84-8050
   VINID: 91D49A5C77A505C6800070002006E44A38
No fault code found.
Readiness: N/A
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 043 E    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1604
   Revision: 00005008    Serial number: CU501905207876 CVN: 29CC5D87
   Coding: 0014
   Shop #: WSC 17734 418 534600
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW26.rod
   VCID: 392F2DF919DA6C13ECC-806C
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 5Q0 614 517 ES    HW: 5Q0 614 517 BP
   Component: ESC           H35 0190
   Revision: 00000000    Serial number: 61839000001159
   Coding: 1F076AA120200C734777060062CB25F8560430E26046A4733841F078D2824A0B00000C6212120B095A35351919323200
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 038007
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 0655960518A4D3EBD1E-8052
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0521338485
   Coding: 032C0C0723
   ASAM Dataset: EV_KessyHellaMQBAB 004052
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 45D75109652218F3984-8010
   Rear lid opener control module:
   Subsystem 1 - Part No SW: 3G0 962 243 B    HW: 3G0 962 243 B
   Component: GEB.F.Heckoef  H17 0904
   Serial number: 58641828
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 565 907 044 CL    HW: 565 907 044 CL
   Component: Climatronic   H04 2202
   Revision: 00001K00
   Coding: 06010104000114011105004800141022
   Shop #: WSC 00040 790 00030
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 678BBB813FEE2AE34A8-8032
   Fresh air blower control module (front):
   A/C pressure/coolant temperature sensor:
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 85419540
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 5Q0 937 084 DH    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H40 0312
   Serial number: 01001918002178
   Coding: 000000000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_BCMMQB 020001
   ROD: EV_BCMBOSCH_020_VW27.rod
   VCID: 015F8519318AF4D3E4C-8054
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Component: G397_RLFSS  H06  0002
   Serial number: 23245413X81A955555A0
   Coding: 80006E
   Steering Column Switch:
   Subsystem 2 - Part No SW: 5Q1 953 521 AG    HW: 5Q1 953 569 A
   Component: Lenks.Modul  H13  0170
   Serial number: 0100270620190C301779
No ASAM data for: "EV_BCMMQB" (SK37)
1 Fault Found:
568836 - ROD - Unknown Error Code
          - 00 [008]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 118
                    Date: 2023.02.26
                    Time: 16:21:47
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058019200
   Coding: 0471555851
   Shop #: WSC 00040 790 00031
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: EV_EPHVA18AU3700000_009_VW37.rod
   VCID: 50F9705DAA60CD5B3B2-8004
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 3205675158FF8728749C814530408700000000000000000004
   Shop #: WSC 00040 790 00038
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D34F116B1626C3B60-8016
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 CM    HW: 3Q0 959 655 CM
   Component: Airbag VW21   006 0720
   Revision: --------    Serial number: 003Z2PDJA2J%
   Coding: 98CCC0C0000000005C5400CF000840000065
   ASAM Dataset: EV_AirbaVW21TS6VW48X 001014
   ROD: EV_AirbaVW21TS6VW48X_VW37.rod
   VCID: 0B43A73103C6AE838E0-805E
   Crash sensor for side airbag: driver side:
   Subsystem 1 - Part No SW: -----------    HW: 454 002 806 19
   Component: SideSensor_Df  008 0887
   Serial number: 357000000001C24D6B3O
   Coding: 2D2D2D
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 2 - Part No SW: -----------    HW: 454 002 806 19
   Component: SideSensor_Pf  008 0887
   Serial number: 358000000009540D6B3O
   Coding: 2D2D2D
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 3 - Part No SW: -----------    HW: 454 802 706 19
   Component: SideSensor_Dr  301 0148
   Serial number: 351005C73EC18000000S
   Coding: 2D2D2D
   Passenger side rear thorax airbag crash sensor:
   Subsystem 4 - Part No SW: -----------    HW: 454 802 606 19
   Component: SideSensor_Pr  301 0148
   Serial number: 352002867EC18000000P
   Coding: 2D2D2D
   Crash sensor for front airbag: driver side:
   Subsystem 5 - Part No SW: -----------    HW: 454 801 803 19
   Component: FrontSensor_D  304 0149
   Serial number: 3550065F28317000000H
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 565 920 790 C    HW: 565 920 790 C
   Component: KOMBI         502 4191
   Coding: 00A40C1E6F8C0008018A77031001000880200000
   Shop #: WSC 80093 222 69422
   ASAM Dataset: EV_DashBoardVDDMQBA0 001042
   ROD: EV_DashBoardVDDMQBA0_001_VW37.rod
   VCID: 1E65DE65A0342B2BF9E-804A
1 Fault Found:
16777126 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_IAA_PSO_0x82 keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 78
                    Date: 2023.02.26
                    Time: 16:33:15
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 29061910803182
   Coding: 030100045F087300231002D2100F00010001070000000000000000000000
   GVL: 01463C000800060040DC80008000C80000000000000200000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW37.rod
   VCID: 70B9D0DD0A20ED5B1B2-8024
   Generator:
   Component: 4-01-13-01-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3V0 919 719 E    HW: 3V0 919 719 E
   Component: E221__MFL-PR6  H03 0180
   Serial number: 000000000C0511090719
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 J    HW: 5Q0 915 181 J
   Component: J367-BDMConti  H03 1051
   Serial number: 7588600300190702095E
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 3Q0 905 861 B    HW: 3Q0 905 861 B
   Component: ELV-MQBB      H05 0020
   Serial number: 19000187961009
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarqMQBA0 002002
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331FD13BB69643260-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 E    HW: 5Q0 959 760 E
   Component: Sitzmemory    H09 0026
   Serial number: Y0007SEU27330
   Coding: 0010000000000500018480818180000000008181000000D400
   Shop #: WSC 12336 024 394758
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   ROD: EV_SeatMemorDriveSide.rod
   VCID: 3FDB43E107FE4223D28-806A
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 B    HW: 2Q0 907 686 B
   Component: HRE3_Kl15_Mst H06 0149
   Serial number: 00000520562087
   Coding: 52954640
   ASAM Dataset: EV_HREntryHellaGen3Kl15 002001
   ROD: EV_HREntryHellaGen3Kl15_002_VW27.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 B    HW: 2Q0 907 685 B
   Component: HRE3_Kl15_Slv  H06 0149
   Serial number: 00000520454237
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 K    HW: 5Q4 959 593 K
   Component: TSG FS        007 0480
   Serial number: 0000381913666
   Coding: 00150920DE00020000001100
   ASAM Dataset: EV_DCU2DriveSideMAXHCONT 001005
   ROD: EV_DCU2DriveSideMAXHCONT_SK37.rod
   VCID: 4DC76929BD52E0B3504-8018
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 407 A    HW: 5Q0 959 163
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000031683760
   Coding: 010200
1 Fault Found:
196726 - Motor for mirror fold-in
          B11F6 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 118
                    Date: 2023.02.26
                    Time: 15:53:25
Address 44: Steering Assist (J500)       Labels:| 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 955026 00
   Coding: 0100001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: EV_SteerAssisVWBSMQBGen2_002_VW48.rod
   VCID: 2B0307B1E386CE836E0-807E
Address 4B: Multifunc. Module (J745)       Labels:| 3Q0-907-338-V2.clb
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
   Serial number: 24051911603413
   Coding: 000000050900052200003D01190000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 003003
   ROD: EV_MultiModulContiVW48X_003.rod
   VCID: 372B2BC12FCE7A631A8-8062
2 Faults Found:
0037 - Databus for Front Lighting
          U12EB 00 [009] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LED_Leimo_identified]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 78
                    Date: 2023.02.26
                    Time: 16:11:40
0032 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 78
                    Mileage: 187822 km
                    Date: 2023.02.26
                    Time: 16:11:40
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 K    HW: 5Q4 959 592 K
   Component: TSG BFS       007 0480
   Serial number: 0000381680695
   Coding: 00150120DE00020000001100
   ASAM Dataset: EV_DCU2PasseSideMAXHCONT 001005
   ROD: EV_DCU2PasseSideMAXHCONT_SK37.rod
   VCID: 4CC1642D4648E9BB47A-8018
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 408 A    HW: 5Q0 959 164
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000031817422
   Coding: 190200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 565 035 864     HW: 565 035 864
   Component: MU-S-N-ER     H41 0477
   Serial number: SKZAZ2W0476882
   Coding: 03230601FF0000000111000100080A002F0208B401200400BE
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW26.rod
   VCID: 5AED9275FC9C870BC56-800E
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H53 8130
   Serial number: SKZ6ZHW2061911
   Data carrier:
   Subsystem 2 - Part No SW: 5L0 051 236 CR    HW: -----------
   Component: ECE AS 2023  --- 1910
   Serial number: --------------------
1 Fault Found:
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 78
                    Date: 2023.02.26
                    Time: 16:12:00
                    Voltage terminal 30: 12.0 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8
   Coding: 1808
   ASAM Dataset: EV_DeckLidCONTIAU736 001017
   ROD: EV_DeckLidCONTIAU736_VW37.rod
   VCID: 48C9583D5230059B632-801C
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 03230601EA421A0D3F1C9E000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: EV_OCULowMQBLGE_004_VW41.rod
   VCID: 3D2739E90DF25033C04-8068
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3QD 980 654 A    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 1611
   Serial number: 29041941K23124
   Coding: 0203070800000401002213468150A90090000E20002000
   ASAM Dataset: EV_MFKBoschMQBB 002041
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 49CF5D39493AFC937CC-801C
Address BB: Door Rear Drv
Cannot be reached
Address BC: Door Rear Pass
Cannot be reached
Address D6: Light Ctrl Left 2 (A31)       Labels: 7P5-941-591.clb
   Part No SW: 7P5 941 591 AH    HW: 7P5 941 591 A
   Component: LED1L         H07 0009
   ASAM Dataset: EV_LED_PLUS_L_KEBODAVW416 001003
   ROD: EV_LED_PLUS_L_KEBODAVW416.rod
   VCID: 025D8A15348CEFCBFD6-8056
1 Fault Found:
0338 - Databus
          U1121 00 [040] - Missing Message
          [can message LCM_Soll_Fkt missing]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 1
                    Date: 2023.02.26
                    Time: 15:46:36
Address D7: Light Ctrl Right 2 (A27)       Labels: 7P5-941-591.clb
   Component: LED1R         H07 0009
   ASAM Dataset: EV_LED_PLUS_R_KEBODAVW416 001003
   ROD: EV_LEDPLUSRightKEBODVW416.rod
1 Fault Found:
0338 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 1
                    Date: 2023.02.26
                    Time: 15:46:36
End----------(Elapsed Time: 01:49, VBatt start/end: 12.4V/12.3V)-----------
skoda log.txt
Someone to help???
