A common error with VAG part numbers
Thanks, I did not realise that.
Can you expand the topic by explaining how trim colours, finishes etc are differentiated in the part numbers? Assuming you know.
I find it almost impossible to discriminate between a O and a 0 on a text/numeric string on a computer screen, side by side as I have typed the difference is clear enough but not amongst other numbers and letters, in fact its only when they are mixed the problem occurs.
G00gle does seem quite good at coping with my handicap!
7 minutes ago, J.R. said:
Assuming you know
Not something I can help with, sorry.
Others are more than welcome to chime in though, if they have useful knowledge of such things.
There are lots of things in ETKA that remain mysterious to me, I'll probably add some later as I think of them, in the hope someone can demystify.  🙂
I recall when ordering front grille, bumper and interior trim plastic parts from TPS that there were suffixes for the colours but not the details or whether it was used consistently.
A handy site to see which part numbers actually are equivalent is skoda-parts.com
Type in a known correct part number for what you want, and it tends to take you to the page selling the latest version, but very helpfully all equivalent part numbers get listed in a grey font just under the main item title.
e.g.
https://www.skoda-parts.com/spare-part/6r0615301c-front-disc-brake-256x22mm-ferodo-4177.html
So yes, what @Breezy_Pete has said about O (as in Oscar) and 0 (as in the number zero), there are no parts I have ever seen that use the letter O.
AFAIK there is also no part that has I (for India) and there is only 1 (as in the number one) used in the parts catalog.
Regards to the question about colour codes, here you can see a basic idea of the choices
Here are some parts snippets, and you can buy some things without any colour preparation
1. 5Q0 919 275 B
So this is the sensor as it comes from the factory
2. 5Q0 919 275 B  GRU
This is the sensor with primer only ready to paint
3. 5Q0 919 133
A seal ring without any specified colour (no longer available)
4. 5Q0 919 133  9B9
A seal ring in Satin Black
5. 5Q0 919 133  704
A seal ring in Grey colour
