Seats ... please help ( if you cam ! )
Hi all
I current;y have a 2015 Octavia 2.0L Diesel Cr Elegance Estate. It has the alcantara heated seats fitted that only have the up / down manual adjuster
I find that after 80 miles or so, my bum / legs are killing me ( like when you are on a plane for too long ) which I put down to the angle of the seat
I see that the Superb has seats that have a tilt adjustment, but I'm not sure Superb seats would fit anyway - however - I have found that they did an Octavia Laurin and Klement version with the same adjustment as the Superb.
Now - assuming that the seats will fit ( as its an Octavia ) and that the wiring is in place for the airbag / heating as per my current seats. would I be able to get the seat controls to work as I see there is another block connector ?
Im not that bothered about having the "set" part, but wondering if this is just a memory module in the seat or somewhere else ?
I will have a look under the seat tomorrow to see if there is an unused connector ( sometimes they use the same loom for all models )
Any thoughts ?
THanks
Andy
