Major 2003 AD replication headache.
Help
Our AD has become a bg headache. I have found out today that one of the DC's at a remote site has not replicated properly since November last year. I am therefore unable to persuade AD to replicate. in AD sites/services I delete the automatically created routes, and do check replication topology. This rebuilds the entries, I then do a replicate now but just end up with a load of errors in the event log. Depending on what server the automatically generated route picks the error varies. I have seen "The RPC service is unavailable" although there is no blocked traffic on the firewall (confirmed by log monitor not dropping packets). I have also seen "The Target Principal Name is Incorrect" and several other errors.
Is anyone an AD Guru who can help get this mess back straight again.
run netdiag and I think dcdiag and see if it shows any errors.
this is DCDiag output from the server at the remote site.
I have changed some key entries. The servername is XXXXXTCF1
Domain Controller Diagnosis
Performing initial setup:
Done gathering initial info.
Doing initial required tests
Testing server: The-Centre\XXXXXTCF1
Starting test: Connectivity
......................... XXXXXTCF1 passed test Connectivity
Doing primary tests
Starting test: Replications
REPLICATION-RECEIVED LATENCY WARNING
XXXXXTCF1: Current time is 2006-06-10 08:34:12.
DC=ForestDnsZones,DC=domain,DC=gov,DC=uk
Last replication recieved from BBBBBBDC01 at 2006-06-08 10:48:31.
Last replication recieved from AAAAAADC02 at 2006-06-08 10:58:31.
Last replication recieved from AAAAAADC01 at 2006-06-08 11:41:38.
DC=DomainDnsZones,DC=domain,DC=gov,DC=uk
Last replication recieved from BBBBBBDC01 at 2006-06-09 03:48:31.
Last replication recieved from AAAAAADC02 at 2006-06-09 03:58:35.
Last replication recieved from AAAAAADC01 at 2006-06-09 04:13:00.
CN=Schema,CN=Configuration,DC=domain,DC=gov,DC=uk
Last replication recieved from AAAAAADC01 at 2006-06-09 04:12:52.
Last replication recieved from BBBBBBDC01 at 2006-06-09 03:48:30.
Last replication recieved from AAAAAADC01 at 2006-06-09 04:12:48.
Last replication recieved from BBBBBBDC01 at 2006-04-18 09:18:29.
Last replication recieved from AAAAAADC02 at 2006-04-18 09:32:24.
Last replication recieved from AAAAAADC01 at 2006-04-18 09:32:28.
......................... XXXXXTCF1 passed test Replications
Starting test: NCSecDesc
......................... XXXXXTCF1 passed test NCSecDesc
Starting test: NetLogons
......................... XXXXXTCF1 passed test NetLogons
Starting test: Advertising
......................... XXXXXTCF1 passed test Advertising
Starting test: KnowsOfRoleHolders
[AAAAAADC01] DsBindWithSpnEx() failed with error -2146893022,
The target principal name is incorrect..
Warning: AAAAAADC01 is the Schema Owner, but is not responding to DS RPC Bind.
[AAAAAADC01] LDAP bind failed with error 8341,
A directory service error has occurred..
Warning: AAAAAADC01 is the Schema Owner, but is not responding to LDAP Bind.
Warning: AAAAAADC01 is the Domain Owner, but is not responding to DS RPC Bind.
Warning: AAAAAADC01 is the Domain Owner, but is not responding to LDAP Bind.
Warning: AAAAAADC01 is the PDC Owner, but is not responding to DS RPC Bind.
Warning: AAAAAADC01 is the PDC Owner, but is not responding to LDAP Bind.
Warning: AAAAAADC01 is the Rid Owner, but is not responding to DS RPC Bind.
Warning: AAAAAADC01 is the Rid Owner, but is not responding to LDAP Bind.
Warning: AAAAAADC01 is the Infrastructure Update Owner, but is not responding to DS RPC Bind.
Warning: AAAAAADC01 is the Infrastructure Update Owner, but is not responding to LDAP Bind.
......................... XXXXXTCF1 failed test KnowsOfRoleHolders
Starting test: RidManager
......................... XXXXXTCF1 failed test RidManager
Starting test: MachineAccount
......................... XXXXXTCF1 passed test MachineAccount
Starting test: Services
......................... XXXXXTCF1 passed test Services
Starting test: ObjectsReplicated
......................... XXXXXTCF1 passed test ObjectsReplicated
Starting test: frssysvol
......................... XXXXXTCF1 passed test frssysvol
Starting test: frsevent
There are warning or error events within the last 24 hours after the
SYSVOL has been shared. Failing SYSVOL replication problems may cause
Group Policy problems.
......................... XXXXXTCF1 failed test frsevent
Starting test: kccevent
An Warning Event occured. EventID: 0x8000061E
Time Generated: 06/10/2006 08:27:45
Event String: All domain controllers in the following site that
An Error Event occured. EventID: 0xC000051F
Event String: The Knowledge Consistency Checker (KCC) has
An Warning Event occured. EventID: 0x80000749
Event String: The Knowledge Consistency Checker (KCC) was
An Warning Event occured. EventID: 0x80000785
Event String: The attempt to establish a replication link for
Time Generated: 06/10/2006 08:28:06
Time Generated: 06/10/2006 08:31:05
Time Generated: 06/10/2006 08:31:26
Time Generated: 06/10/2006 08:31:27
......................... XXXXXTCF1 failed test kccevent
Starting test: systemlog
An Error Event occured. EventID: 0x40000004
Time Generated: 06/10/2006 07:40:37
Event String: The kerberos client received a
Time Generated: 06/10/2006 07:40:58
Time Generated: 06/10/2006 07:51:43
Time Generated: 06/10/2006 07:55:59
Time Generated: 06/10/2006 08:16:39
Time Generated: 06/10/2006 08:17:58
Time Generated: 06/10/2006 08:25:05
Time Generated: 06/10/2006 08:25:11
Time Generated: 06/10/2006 08:25:14
Time Generated: 06/10/2006 08:25:35
......................... XXXXXTCF1 failed test systemlog
Starting test: VerifyReferences
......................... XXXXXTCF1 passed test VerifyReferences
Running partition tests on : ForestDnsZones
Starting test: CrossRefValidation
......................... ForestDnsZones passed test CrossRefValidation
Starting test: CheckSDRefDom
......................... ForestDnsZones passed test CheckSDRefDom
Running partition tests on : DomainDnsZones
......................... DomainDnsZones passed test CrossRefValidation
......................... DomainDnsZones passed test CheckSDRefDom
Running partition tests on : Schema
......................... Schema passed test CrossRefValidation
......................... Schema passed test CheckSDRefDom
Running partition tests on : Configuration
......................... Configuration passed test CrossRefValidation
......................... Configuration passed test CheckSDRefDom
Running partition tests on : domain
......................... domain passed test CrossRefValidation
......................... domain passed test CheckSDRefDom
Running enterprise tests on : domain.gov.uk
Starting test: Intersite
......................... domain.gov.uk passed test Intersite
Starting test: FsmoCheck
......................... domain.gov.uk passed test FsmoCheck
This is the DCDiag from one of the DCs at the main office.
Testing server: bbbbbbb-Hs\XXXXXXDC02
......................... XXXXXXDC02 passed test Connectivity
Doing primary tests
Testing server: Three-Rivers-Hs\XXXXXXDC02
XXXXXXDC02: Current time is 2006-06-10 08:40:47.
Last replication recieved from XXXXTCF1 at 2005-11-24 07:34:49.
WARNING: This latency is over the Tombstone Lifetime of 60 days!
......................... XXXXXXDC02 passed test Replications
......................... XXXXXXDC02 passed test NCSecDesc
......................... XXXXXXDC02 passed test NetLogons
......................... XXXXXXDC02 passed test Advertising
......................... XXXXXXDC02 passed test KnowsOfRoleHolders
......................... XXXXXXDC02 passed test RidManager
......................... XXXXXXDC02 passed test MachineAccount
......................... XXXXXXDC02 passed test Services
......................... XXXXXXDC02 passed test ObjectsReplicated
......................... XXXXXXDC02 passed test frssysvol
......................... XXXXXXDC02 failed test frsevent
......................... XXXXXXDC02 passed test kccevent
......................... XXXXXXDC02 passed test systemlog
......................... XXXXXXDC02 passed test VerifyReferences
The netdiag tests pass on each end from what I can see.
So how can I get this working again.
