Lots of errors on dash
123ashleyp23
Recommended Posts
This is the recent scan from odbeleven.
Date: 2023-04-07 12:59
VIN: TMBMJ7NS4J8011202
Car: Skoda Kodiaq
Year: 2018
Body type: SUV
Engine: DFGA
Mileage: 147312 KM
8104 DC/DC Converter Control Module HV
Trouble codes:
No trouble codes found
8105 DC/DC Converter Control Module 12V
Trouble codes:
8116 Sound enhancement 2
Trouble codes:
01 Engine
System description: R4 2.0l TDI
Software number: 04L906026JC
Software version: 3612
Hardware number: 04L907309P
Hardware version: H25
ODX name: EV_ECM20TDI01104L906026JC
ODX version: 004003
Long coding: 0119001203271D083000
Trouble codes:
U112300 - Databus error value received
Intermittent
Date: 2023-04-01 19:38:37
Mileage: 147235 km
Priority: 6
Malfunction frequency counter: 4
Unlearning counter: 255
Engine speed: 1496.00 1/min
Normed load value: 0.0 %
Vehicle speed: 78 km/h
Coolant temperature: 88 °C
Intake air temperature: 73 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 14.560 V
Dynamic environmental data: 20962817E0000017DD0417DE00001187FF55
U041500 - Invalid Data Received From Anti-Lock Brake System Control Module
Intermittent
Mileage: 147235 km
Priority: 2
Malfunction frequency counter: 5
Engine speed: 1481.50 1/min
Vehicle speed: 77 km/h
Dynamic environmental data: 209628106C0311A600001139000010FB113C16250B2312FB0BB4
02 Transmission
Trouble codes:
03 Brakes
System description: ESC
Software number: 5Q0614517CE
Software version: 0413
Hardware number: 5Q0614517AC
Serial number: 51597000000805
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 036010
Long coding: 6007929F44210B6D4779070062C549064922D0E2E046927530635068C00A4200002F641A1B13111435351919323200
Trouble codes:
C101B29 - Right front ABS wheel speed sensor Implausible signal
Intermittent
Mileage: 147235 km
Priority: 1
Malfunction frequency counter: 2
Unlearning counter: 252
Extended Freeze Frames: 0000001812000000C2600000000000000240B000000010
C102D00 - Tire pressure warning
static
Date: 2023-03-31 22:27:02
Mileage: 147185 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 246
Extended Freeze Frames: 0000001872000000AB00FF000004000002438001010010
C114602 - Tire pressure monitoring display Signal error
Intermittent
Date: 2023-04-01 19:38:47
Mileage: 147235 km
Priority: 2
Unlearning counter: 37
Extended Freeze Frames: 0003001812000000BC600000FD0100000240B000000010
C10E2F0 - Control module for electro-mechanical parking brake Wheel speed sensor implausible signal
static
Mileage: 147235 km
Priority: 3
Extended Freeze Frames: 0003001812000000BC600000FF0200000240B000000010
04 Steering Angle Sensor
Trouble codes:
06 Passenger Seat
Trouble codes:
07 Display
Trouble codes:
08 Air Conditioning
System description: Climatronic
Software number: 565907044BF
Software version: 2001
Hardware number: 565907044BF
Hardware version: H04
ODX name: EV_ACClimaBHBVW37X
ODX version: 006146
Long coding: 16110104002110011005000800101022
Subsystems:
System description: G238 _AQS
Software version: 0119
Hardware version: H30
Serial number: 60735811
Trouble codes:
B10AF04 - Air quality sensor Faulty
Intermittent
Date: 2023-04-01 00:54:08
Mileage: 147197 km
Priority: 3
Malfunction frequency counter: 12
Dynamic environmental data: 02867A2609162650FFFF
09 Central Electrics
System description: BCM PQ37BOSCH
Software number: 5Q0937086BL
Software version: 0242
Hardware number: 5Q0937086BG
Hardware version: 034
Serial number: 865801061701BK
ODX name: EV_BodyContrModul1UDSBosc
ODX version: 018001
Subsystems:
System description: WWS326 170411
Software version: 0907
Hardware version: 051
Serial number: 887253F0401710100766
Long coding: 164DDD
System description: RLHS
Software version: 0105
Hardware version: 042
Serial number: S8Y17M06D09H07M15S56
Long coding: 00885D
System description: Sensor, DWA
Software version: 0316
Hardware version: 005
Serial number: 000000000ZY171240Z9N
System description: Sirene, DWA
Software version: 0314
Serial number: 00000000000069883310
Trouble codes:
B121715 - Left low beam headlamp bulb Open circuit/short circuit to B+
Intermittent
Date: 2023-04-01 02:31:22
Mileage: 147209 km
Priority: 1
Terminal 15 status: On
Terminal 50 status: Off
Voltage: 13.7 V
Outside air temperature: 16.5 °C
Status Bremslichtschalter (HW): Off
Status Bremslichtschalter (CAN): Off
Off: not activated
Parking light: not activated
Automatic high beam assist: operated
Low beam: not activated
Parking light left: not activated
Parking light right: not activated
Letzte Weckursache/ Werte [00;2E]: keine Störschutzursache
CAN-Bus_aktiv: On
B202300 - Function limitation due to active protector function
Intermittent
Date: 2023-04-01 02:50:00
Mileage: 147227 km
Priority: 1
Unlearning counter: 40
Terminal 15 status: Off
Voltage: 12.7 V
Outside air temperature: 10.0 °C
Status Bremslichtschalter (CAN): On
Off: not activated
Letzte Weckursache/ Werte [00;2E]: kl30g_pwm
CAN-Bus_aktiv: On
0E Media Player
Trouble codes:
11 Engine 2
Trouble codes:
13 Adaptive Cruise Control
System description: ACCCONTIMQB
Software number: 2Q0907572M
Software version: 0233
Hardware number: 2Q0907572B
Hardware version: H02
ODX name: EV_ACCMRRCONTIVW376
ODX version: 002012
Long coding: 2A00600150FF8728749C8145004087
Trouble codes:
Intermittent
Mileage: 147235 km
Priority: 4
Dynamic environmental data: 028585028D4D10111B411012FFC0102E06
Intermittent
Mileage: 147235 km
Priority: 4
Intermittent
Mileage: 147235 km
Priority: 4
U112200 - Databus implausible message
Intermittent
Date: 2023-04-01 19:38:38
Mileage: 147235 km
Priority: 6
Intermittent
Date: 2023-04-01 19:40:52
Mileage: 147237 km
Priority: 6
Dynamic environmental data: 028581028D4D10111B4110120280102E06
Intermittent
Mileage: 147235 km
Priority: 6
Intermittent
Mileage: 147235 km
Priority: 6
Dynamic environmental data: 028585028D4D10111B411012FF80102E06
15 Airbag
System description: Airbag VW21
Software number: 3Q0959655BH
Software version: 0702
Hardware number: 3Q0959655BH
Hardware version: 006
Serial number: 003W4PBBYZSB
ODX name: EV_AirbaVW21TS6VW48X
ODX version: 001014
Long coding: 98CCC0C0000000005C5400CF008840000065
Subsystems:
System description: SideSensor_Df
Software version: 0887
Hardware version: 008
Serial number: 35700000000EE910A42Q
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 35800000000936014321
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 0148
Hardware version: 301
Serial number: 351003E82A50E000000M
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 352008989F60F000000.
Long coding: 2D2D2D
System description: FrontSensor_D
Software version: 0149
Hardware version: 304
Serial number: 35500D084C1100000009
Long coding: 2D2D2D
Trouble codes:
16 Steering Column
System description: Lenks.Modul
Software number: 5Q0953521ER
Software version: 0235
Hardware number: 5Q0953569A
Hardware version: 075
Serial number: 20170609400508
ODX name: EV_SMLSVALEOMQB
ODX version: 001015
Long coding: 1404
Trouble codes:
17 Dashboard
System description: KOMBI
Software number: 565920941A
Software version: 0310
Hardware number: 565920941A
Hardware version: 202
ODX name: EV_DashBoardVDDMQBAB
ODX version: 009060
Long coding: 27A40094A3808E0001886A010001000800000000
Trouble codes:
U101400 - Control module incorrectly coded
Intermittent
Mileage: 147185 km
Priority: 2
Malfunction frequency counter: 3
Unlearning counter: 31
U112100 - Databus missing message
static
Date: 2023-04-01 00:17:44
Mileage: 147185 km
Priority: 6
19 Gateway
System description: GW MQB High
Software number: 3Q0907530G
Software version: 5304
Hardware number: 3Q0907530C
Hardware version: 518
Serial number: 06061710802737
ODX name: EV_GatewNF
ODX version: 013023
Long coding: 030100045F087300EB000248080F00010001070000000000000000000000
Subsystems:
System description: J367-BDMConti
Software version: 1050
Hardware version: H03
Serial number: 7588610000170527014A
System description: E221__MFL-PR6
Software version: 0160
Serial number: 000000000A1309010617
Trouble codes:
U112600 - Undefined control module No communication
static
Mileage: 147185 km
Priority: 2
Malfunction frequency counter: 14
Supply voltage, terminal 30: 12.0 V
Terminal 15: On
U106600 - Radio No Communication
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U100F00 - Special purpose vehicle control module No communication
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U020900 - Lost Communication With “Seat Control Module B”
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U106A00 - Digital sound system control module No Communication
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U105E00 - Media player in position 1 No Communication
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U010100 - Lost Communication with TCM
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U014A00 - Lost Communication With Battery Energy Control Module "C"
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U131F00 - Battery control additional memory 1 no communication
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
static
Mileage: 147185 km
Priority: 2
Terminal 15: On
U140600 - Static current too high
Intermittent
Date: 2023-04-01 08:01:40
Mileage: 147227 km
Priority: 7
Supply voltage, terminal 30: 12.3 V
Terminal 15: Off
1B Active Steering
Trouble codes:
21 Battery Energy Module
Trouble codes:
22 All Wheel Control
System description: Haldex4Motion
Software number: 0CQ907554H
Software version: 7083
Hardware number: 0CQ525130
Hardware version: H52
Serial number: HA1-00022.04.1700010404
ODX name: EV_AllWheelContrHA1VW37X
ODX version: 004013
Long coding: 0101
Trouble codes:
Intermittent
Date: 2023-04-01 19:38:36
Mileage: 147235 km
Priority: 6
Unknown ambient data: 460F14FE229886
2B Steering Column Lock
System description: ELV-MQBB
Software number: 3Q0905861
Software version: 0032
Hardware number: 3Q0905861
Hardware version: H05
Serial number: 17000144779009
ODX name: EV_ELVMarquMQBB
ODX version: 001007
Long coding: 0000000000000000
Trouble codes:
Intermittent
Mileage: 147235 km
Priority: 6
Result lock conditions: Invalid
ESCL locked: No
ESCL unlocked: Yes
Lock sensor: not activated
Unlock sensor: operated
Error mode 1: not active
Error mode 2: not active
Clamp S: On
Clamp 15: On
Clamp 15 status: valid
Remotestart: not active
Driver door: closed
Central locking locked external: unlocked
Central locking safed external: Vehicle not secured
Clamp Request: No
Request highside lock: No
HW highside lock: Off
Highside unlock: No
Motor break: not active
Activation lowside unlock: Off
Activation lowside lock: Off
I2C overflow: No
I2C error pathflags: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C length failure: No
I2C error sda: No
I2C communication failure: i2c no comm failure
I2C state esp 10: i2c cnd false
I2C cnd haco message: valid
Coco reset: No
Coco supply: On
Password IMS OK: Yes
Signature IMS OK: Yes
IMS responded: Yes
Positive authentification in current KL15 cycle: No
Lifestate: Immobilizer download obtained
Authentication valid (T1): No
State of authentication state machine: WFS_AUTH_INIT_e
Vehicle speed: 96.31 km/h
UBat internal: 12.6 V
UMotorBridge: 6.8 V
Lock condition engine speed: Condition not met
Lock condition clamp S: Condition not met
Lock condition clamp 15: Condition not met
Lock condition E2E clamp status: Condition not met
Lock condition timeout clamp status: Condition met
Lock condition vehicle speed: Condition not met
Lock condition E2E vehicle speed: Condition not met
Lock condition timeout vehicle speed: Condition not met
Lock condition Mode1: Condition met
Lock condition drive readiness: Condition met
Lock condition selector lever position parking: Condition met
Clamp enable ESCL: not enabled
Lock condition timeout distance pulse: Condition met
Lock condition E2E distance pulse: Condition met
Lock condition difference distance pulse: Condition not met
Intermittent
Date: 2023-04-01 19:42:48
Mileage: 147237 km
Priority: 6
ESCL locked: No
ESCL unlocked: Yes
Clamp S: Off
Clamp 15: Off
Driver door: open
Clamp Request: No
Highside unlock: No
I2C overflow: No
I2C resetinfo: No
I2C error cpu: No
I2C error rom: No
I2C error ram: No
I2C error sda: No
Coco reset: No
Coco supply: On
IMS responded: Yes
Vehicle speed: 0.00 km/h
UBat internal: 11.7 V
UMotorBridge: 6.4 V
Lock condition engine speed: Condition met
Lock condition clamp S: Condition met
Lock condition clamp 15: Condition met
Lock condition E2E clamp status: Condition met
34 Chassis Control
Trouble codes:
3B Sensor Electronics
Trouble codes:
3D Special Function
Trouble codes:
42 Driver Door
System description: TSG FS
Software number: 5Q4959393E
Hardware number: 5Q4959393B
Hardware version: 011
Serial number: 0000261015019
ODX name: EV_DCUDriveSideEWMAXCONT
ODX version: 006001
Long coding: 001400208001040000001100
Subsystems:
System description: FOND_FHSG_DRV
Software version: 0007
Serial number: 00000000000015215036
Long coding: 1D0200
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144T
Software version: 1072
Hardware number: 5Q0909144R
Hardware version: 128
ODX name: EV_SteerAssisMQB
ODX version: 013144
Long coding: 0107
Trouble codes:
Intermittent
Mileage: 147235 km
Priority: 6
Malfunction frequency counter: 255
Motor status: 2
System status: Driving mode
Supply voltage: 13.25 V
Temperature: 26.0 °C
KFC: 4d
KFA: 4
Environmental conditions: 21
uAdSensI_U1V2Filtered_gdu16: 1.20 V
uAdSensI_U5VFiltered_xdu16: 0.00000 V
uioUdNotFilt_xdu16: 13.44 V
uAdSensI_SwitchedKl30_xdu16: 13.44 V
NoInitCause_AsicSens: [0x00] ASC_CTRL_SAS_NO_ERR
NoInitCause_RackPos_Rohwert: 0
RP_VALCNTSAV: Not activated
RP_DIAGJOB: Not activated
RP_RPS: Not activated
RP_KMN_RACKPOS_SET: Not activated
RP_STARTUP: Not activated
RP_L2PLAUSI: Not activated
RP_INDEXPLAUSI: Not activated
RP_WHLSPDPLAUSI: Not activated
RP_RUKUCNTR: Not activated
RP_UNDERVOLT: Not activated
RP_CNTERR: Not activated
Intermittent
Mileage: 147235 km
Priority: 6
Motor status: 2
KFC: 4f
KFA: 4
Intermittent
Mileage: 147235 km
Priority: 6
Motor status: 2
KFC: 51
KFA: 4
uioUdNotFilt_xdu16: 13.31 V
uAdSensI_SwitchedKl30_xdu16: 13.31 V
46 Comfort System
Trouble codes:
47 Sound System
Trouble codes:
4F Central Electrics 2
Trouble codes:
52 Passenger Door
System description: TSG BFS
Software number: 5Q4959392E
Hardware number: 5Q4959392B
Serial number: 0000261032030
ODX name: EV_DCUPasseSideEWMAXCONT
ODX version: 006001
Subsystems:
System description: FOND_FHSG_PSG
Serial number: 00000000000015127616
Long coding: 050200
Trouble codes:
56 Radio
System description: MU-S-ND-ER
Software number: 5Q0035874C
Software version: 0456
Hardware number: 5Q0035874C
Hardware version: H41
Serial number: SKZAZ2T5246641
ODX name: EV_MUStd4CTSAT
ODX version: 001022
Long coding: 03231601FF00000051111201C08808002F0208C601208500CE
Subsystems:
System description: ABT_Std-2_Nav
Software version: 8120
Hardware version: H50
Serial number: SKZ6ZHT1612405
System description: ECE1 2022
Software version: 1720
Hardware version: ---
Serial number: --------------------
Trouble codes:
5F Multimedia
ODX version: 001022
Subsystems:
Trouble codes:
75 Telematics
System description: OCULowMQBLGE
Software number: 5NA035284B
Software version: 0717
Hardware number: 5NA035284B
Hardware version: H17
ODX name: EV_OCULowMQBLGE
ODX version: 004044
Long coding: 03231601EA421A0D3B1C9E020045400382E608
Trouble codes:
76 Parking Assistance
System description: PDC 4 Kanal
Software number: 3Q0919283A
Software version: 0029
Hardware number: 3Q0919283
Hardware version: H07
Serial number: 001805177478091982
ODX name: EV_EPHBO14VW3260000
ODX version: 007015
Long coding: 0061450001
Trouble codes:
Intermittent
Mileage: 147235 km
Priority: 6
Intermittent
Mileage: 147235 km
Priority: 6
Intermittent
Mileage: 147235 km
Priority: 6
80 Battery Regulation
Trouble codes:
84 Night Vision
Trouble codes:
B7 Start System Interface
System description: VWKESSYMQB
Software number: 3Q0959435F
Software version: 0906
Hardware number: 3Q0959435F
Hardware version: 027
Serial number: 0442277321
ODX name: EV_KessyHellaMQBAB
ODX version: 004041
Long coding: 000F0F060F
Trouble codes:
Intermittent
Mileage: 147235 km
Priority: 6
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: Off
Terminal_50_Kessy_actual_value: Off
ZAT_pressed: Off
Park selector lever position: Not engaged and not locked
Request active: Condition not met
Enabling steering column lock: Condition not met
Enabling immobilizer: Condition not met
No active error mode: Condition met
Key signature validity: Condition met
---: 13.358 V
Driver information key position copy workshop: not active
Driver information, roll warning: not active
Driver information, emergency shutdown: not active
Internal_key_position: no_message
Driver information comfort switching: not active
Vehicle speed: 97.2 km/h
Engine speed: 2208.0 1/min
---: Vehicle locked internally
Approach to the inside: not active
Actuation to the inside: not active
Approach to the outside: not active
Actuation to the outside: not active
Pulling actuation, outside door handle: not active
Coding information: Not coded
Driver door: Closed
Front passenger door: Closed
Left rear door: Closed
Right rear door: Closed
Active_LF_scans: Init
ID sensor 1 authentication, status: No response
ID sensor 2 authentication, status: No response
ID sensor 3 authentication, status: No response
ID sensor 4 authentication, status: No response
SPN_Byte 0: 0
SPN_Byte 1: 0
SPN_Byte 2: 0
Link to comment
Share on other sites
03 Brakes
ODX version: 036010
Trouble codes:
Intermittent
Edited by Salad_Fingers
typo
Link to comment
Try and get yourself an ATE sensor for the front right... presumably that's what brand will be fitted to it already. ECP don't seem to have ATE sensors in stock at the moment but you might find them elsewhere, £50ish.
If you can get the sensor out easily just check what brand it is and replace with the same.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
