Lots of errors on dash
Hi All,
Recently alot of warnings popped up on dash (tpms, esp, parking pilot etc).
Once I park the car and turn off the engine the light seem to vanish on each trip.
What  I have done so far:
1) Changed 12v battery to a new one/ New one now on with errors still coming up
2) Move the steering wheel right and left and the lights go out - then come back on after a short journey
I have obbeleven and vcds so any coding etc could help?
SKODA KODIAQ 4X4 2.0 2018
Ash
Edited by 123ashleyp23
Pull the codes out of the car with these tools, VCDS is best bet.
Post the log (erase your VIN if you prefer)
will do a scan and add shortly
Wednesday,05,April,2023,13:06:11:16365
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86
VCDS Version: 20.4.1.0  HEX-V2 CB: 0.4508.4
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: TMBMJ7NS4J8011202   License Plate:
Mileage: 147185km-91456mi   Repair Order:
Chassis Type: NS-SK37 (3Q0)
Scan: 01 02 03 05 06 07 08 09 0E 10 11 31 13 15 16 17 19 1B 22 2B
          34 3B 3D 42 44 46 47 52 5F 61 75 80 84 8104 8105
VIN: TMBMJ7NS4J8011202   Mileage: 147185km-91456miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Cannot be reached 0100
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 0100
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Cannot be reached 0100
07-Control Head -- Status: Cannot be reached 0100
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 0100
10-Park/Steer Assist -- Status: Malfunction 0010
11-Engine II -- Status: Cannot be reached 0100
31-Engine other -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: Cannot be reached 0100
22-AWD -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: Malfunction 0010
34-Level Control -- Status: Cannot be reached 0100
3B-Sensor Elect. -- Status: Cannot be reached 0100
3D-Special Function -- Status: Cannot be reached 0100
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 0100
47-Sound System -- Status: Cannot be reached 0100
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: Cannot be reached 0100
75-Telematics -- Status: OK 0000
80-Batt. reg. aux. accum. -- Status: Cannot be reached 0100
84-Night Vision -- Status: Cannot be reached 0100
8104-DC/DC Converter HV -- Status: Cannot be reached 0100
8105-Unknown Address: 8105 -- Status: Cannot be reached 0100
Address 01: Engine (J623-DFGA)       Labels: None
   Part No SW: 04L 906 026 JC    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H25 3612
   Revision: B4H25---
   Coding: 0119001203271D083000
   Shop #: WSC 34419 004 1048576
   ASAM Dataset: EV_ECM20TDI01104L906026JC 004003
   ROD: EV_ECM20TDI01104L906026GQ_004.rod
   VCID: 74B1DCCD7E38D17B473-8020
6 Faults Found
11901 - Manifold Pressure / Boost Sensor (G31)
          P0236 00 [032] - Implausible Signal
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 146975 km
                    Date: 2023.03.30
                    Time: 20:23:24
                    Engine speed: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 43 °C
                    Ambient air pressure: 1020 mbar
                    Voltage terminal 30: 11.960 V
                    Unlearning counter according OBD: 36
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 2007.6 hPa
                    Engine status: COENG_FINISH
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
17158 - Databus
          U1123 00 [040] - Received Error Message
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 14
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:12
                    Engine speed: 2928.00 /min
                    Normed load value: 51.8 %
                    Vehicle speed: 100 km/h
                    Coolant temperature: 75 °C
                    Intake air temperature: 87 °C
                    Ambient air pressure: 1010 mbar
                    Voltage terminal 30: 14.500 V
                    Unlearning counter according OBD: 40
                    Drivetrain coordinator: ACC fault status-Bits 0-7: 0
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 0
                    Acceleration: 0.367 m/s²
5244 - Fuel Pressure Sensor (G247)
          P0193 00 [032] - Short to Plus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 146975 km
                    Date: 2023.03.30
                    Time: 20:23:24
5169 - Manifold Pressure / Boost Sensor (G31)
          P0238 00 [032] - Signal too High
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 146975 km
                    Date: 2000.00.00
                    Time: 00:00:00
                    Intake air temperature: 42 °C
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 4131.2 hPa
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
12888 - Implausible Data Received from ABS Control Module
          U0415 00 [040] - -
          [Tip-TNF 208162]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 13
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:13
                    Engine speed: 1839.50 /min
                    Normed load value: 68.6 %
                    Vehicle speed: 81 km/h
                    Coolant temperature: 36 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 14.760 V
                    Engine status: COENG_RUNNING
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
7150 - Implausible Data Received from Steering Angle Sensor Module (G85)
          U0428 00 [040] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Mileage: 146944 km
                    Date: 2023.03.30
                    Time: 00:00:45
                    Coolant temperature: 35 °C
                    Intake air temperature: 30 °C
                    Voltage terminal 30: 11.860 V
                    Unlearning counter according OBD: 39
                    CAN status - engine control module-Bits 0-7: 0
                    Cruise Control System (CCS): status-Bits 0-7: 0
Readiness: 0 0 0 0 0
Address 02: Auto Trans
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: None
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 51597000000805
   Coding: 6007929F44210B6D4779070062C549064922D0E2E046927530635068C00A4200002F641A1B13111435351919323200
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 036010
   ROD: EV_Brake1UDSContiMK100IPB_036_SK37.rod
   VCID: 76B5E6C56844C36B797-8022
5 Faults Found
0063 - Front Right Wheel Speed Sensor
          C101B 29 [008] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 3
                    Reset counter: 246
                    Mileage: 146946 km
                    Date: 2023.03.30
                    Time: 11:12:55
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 28
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:02:59
16401 - Tire Pressure Warning
          C102D 00 [137] - -
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 3
                    Reset counter: 245
                    Mileage: 146976 km
                    Date: 2023.03.30
                    Time: 20:40:28
16417 - Display for Tire Pressure Monitoring
          C1146 02 [008] - Signal Failure
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 31
                    Mileage: 146946 km
                    Date: 2023.03.30
                    Time: 11:13:05
32993 - Control Module for Electric Parking Brake
          C10E2 F0 [008] - RPM Sensor Implausble Signal
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 9
                    Reset counter: 31
                    Mileage: 146946 km
                    Date: 2023.03.30
                    Time: 11:12:55
Address 05: Acc/Start Auth. (J518)       Labels:* Redir Fail!
   Part No SW: 3Q0 959 435 F    HW: 3Q0 959 435 F
   Component: VWKESSYMQB    027 0906
   Revision: 00027000    Serial number: 0442277321
   Coding: 000F0F060F
   Shop #: WSC 33361 790 00063
   ASAM Dataset: EV_KessyHellaMQBAB 004041
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3D2739E90DF2503378D-8068
   Sensor Controlled Power Rear Lid:
2 Faults Found
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [Tip-TNF 204459]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 146889 km
                    Date: 2023.03.30
                    Time: 10:34:19
                    Terminal_15_Kessy_specified_value: On
                    Terminal_15_Kessy_actual_value: On
                    Terminal_15_central electric_actual_value: On
                    Terminal_15red_Kessy_specified_value: On
                    Terminal_15red_Kessy_actual_value: On
                    Terminal_S_Kessy_specified_value: On
                    Terminal_S_Kessy_actual_value: On
                    Terminal_S_central electric_actual_value: On
                    Terminal_50_Kessy_specified_value: On
                    Terminal_50_Kessy_actual_value: On
                    ZAT_pressed: On
                    Park selector lever position: Not engaged and not locked
                    Request active: Condition not met
                    Enabling Steering Column Lock: Condition not met
                    Enabling immobilizer: Condition met
                    No active error mode: Condition met
                    Key signature validity: Condition met
                    Control Module Voltage: 8.436 V
                    Driver information key position copy workshop: not active
                    Driver information: roll warning: not active
                    Driver information: emergency shutdown: not active
                    Internal_key_position: no_message
                    Driver information comfort switching: not active
                    Vehicle speed: 0.0 km/h
                    Engine speed: 95.5 /min
                    Status of vehicle locking: Vehicle unlocked
                    Approach to the inside: not active
                    Actuation to the inside: not active
                    Approach to the outside: not active
                    Actuation to the outside: not active
                    Pulling actuation: outside door handle: not active
                    Coding information: Not coded
                    Driver door: closed
                    Front Passenger Door: closed
                    Left rear door: closed
                    Right rear door: closed
                    Active_LF_scans: Init
                    ID sensor 1 authentication: status: No response
                    ID sensor 2 authentication: status: No response
                    ID sensor 3 authentication: status: No response
                    ID sensor 4 authentication: status: No response
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12786207 - Databus
          U1123 00 [008] - Received Error Message
          [Tip-TNF 241778]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 31
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:13
                    Terminal_50_Kessy_specified_value: OFF
                    Terminal_50_Kessy_actual_value: OFF
                    ZAT_pressed: OFF
                    Enabling immobilizer: Condition not met
                    Control Module Voltage: 14.585 V
                    Vehicle speed: 100.2 km/h
                    Engine speed: 2920.0 /min
                    Status of vehicle locking: Vehicle locked internally
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
Address 06: Seat Mem. Pass
Cannot be reached
Address 07: Control Head
Cannot be reached
Address 08: Auto HVAC (J255)       Labels:* None
   Part No SW: 565 907 044 BF    HW: 565 907 044 BF
   Component: Climatronic   H04 2001
   Revision: 00001K00
   Coding: 16110104002110011005000800101022
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_SK37.rod
   VCID: 6099A09DDAC05DDB33B-8034
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
   Subsystem 3 - Part No SW: 5Q0 907 659 C    HW: 5Q0 907 659 C
   Component: G238 _AQS  H30 0119
   Serial number: 60735811
2 Faults Found
263425 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 45
                    Reset counter: 31
                    Mileage: 146889 km
                    Date: 2023.03.30
                    Time: 00:49:15
                    Voltage terminal 30: 11.0 V
                    Outside air temperature: 11.5 °C
                    System run time-Engine running time: 0 s
                    System run time-Terminal 15 on: 255 s
1048838 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 146889 km
                    Date: 2023.03.30
                    Time: 00:54:24
                    Voltage terminal 30: 10.8 V
                    CAN input signal(s) status-Transport mode: On
                    CAN input signal(s) status-Static current measuring mode: OFF
                    CAN input signal(s) status-Windshield wiper: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Wipe wash: OFF
                    CAN input signal(s) status-Rear window heater actual value: OFF
                    CAN input signal(s) status-Back-up light: OFF
                    CAN input signal(s) status-Actual value of windshield heater: OFF
Address 09: Cent. Elect. (J519)       Labels: None
   Part No SW: 5Q0 937 086 BL    HW: 5Q0 937 086 BG
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 865801061701BK
   Shop #: WSC 33361 790 00058
   ASAM Dataset: EV_BodyContrModul1UDSBosc 018001
   ROD: EV_BCMBOSCH_018.rod
   VCID: 0557910925A2D8F360D-8050
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 567 955 119     HW: 567 955 119
   Component: WWS326 170411  051 0907
   Serial number: 887253F0401710100766
   Coding: 164DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B
   Component: RLHS  042 0105
   Serial number: S8Y17M06D09H07M15S56
   Coding: 00885D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY171240Z9N
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000069883310
   Relative Air Humidity Interior Sender:
2 Faults Found
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [009] - Open or Short to Plus
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 242
                    Mileage: 146975 km
                    Date: 2023.03.30
                    Time: 20:28:27
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 28
                    Mileage: 146972 km
                    Date: 2023.03.30
                    Time: 11:38:03
Address 0E: Media Player 1
Cannot be reached
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 3Q0 919 283 A    HW: 3Q0 919 283
   Component: PDC 4 Kanal   H07 0029
   Serial number: 001805177478091
   Coding: 0061450001
   ASAM Dataset: EV_EPHBO14VW3260000 007015
   ROD: EV_EPHBO14VW3260000_SK37.rod
   VCID: 353721C935C28873B0D-8060
3 Faults Found
13637412 - Databus
          [Tip-TNF 205948]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 31
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:12
13637425 - Databus
          [Tip-TNF 200624]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 31
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:12
13637426 - Databus
          [Tip-TNF 202621]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 18
                    Reset counter: 31
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:13
Address 11: Engine II
Cannot be reached
Address 13: Auto Dist. Reg        Labels: None
   VCID: 55F781499582A87350D-8000
No ASAM data for: "Unknown" (SK37)
No fault code found.
Address 15: Airbags        Labels: None
Address 16: Steering wheel        Labels: None
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 565 920 941 A    HW: 565 920 941 A
   Component: KOMBI         202 0310
   Coding: 27A40014A2808E0001886A010001000800000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009060
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 1A6DD275BC1C470BBDF-804E
1 Fault Found
13636608 - Control Module Incorrectly Coded
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 27
                    Reset counter: 246
                    Mileage: 146944 km
                    Date: 2023.03.30
                    Time: 00:38:00
Address 19: CAN Gateway (J533)       Labels:* None
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 06061710802737
   Coding: 030100045F087300EB000248080F00010001070000000000000000000000
   ASAM Dataset: EV_GatewNF 013023
   ROD: EV_GatewNF_VW37.rod
   VCID: 33331FD13BB696439E9-8066
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0160
   Serial number: 000000000A1309010617
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5QA 915 181 C    HW: 5QA 915 181 C
   Component: J367-BDMConti  H03 1050
   Serial number: 7588610000170527014A
21 Faults Found
131606 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 237744]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Supply voltage: Terminal 30: 12.2 V
                    Terminal 15: On
131608 - Radio
          U1066 00 [009] - No Communication
          [Tip-TNF 237745]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131617 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 232876]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131623 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 232878]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131628 - Control Module for Special Purpose Vehicles
          U100F 00 [009] - No communication
          [Tip-TNF 243715]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131661 - Seat/Mirror Postion Control Passenger - Driver
          U0209 00 [009] - No Communications
          [Tip-TNF 243719]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131665 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 232885]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131669 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 222741]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131695 - Digital sound System control module
          U106A 00 [009] - No Communication
          [Tip-TNF 223115]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131696 - Media player in position 1
          U105E 00 [009] - No Communication
          [Tip-TNF 243722]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131703 - No Communication with Transmission Control Module
          U0101 00 [009] - -
          [Tip-TNF 232891]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131704 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 228402]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131723 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 228022]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131724 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 236727]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131726 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 236728]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131740 - Battery Energy Control Module 2
          U014A 00 [009] - No Communication
          [Tip-TNF 270354]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131756 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 228029]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131758 - Battery Regulation Auxiliary Storage
          U131F 00 [009] - No Communication
          [Tip-TNF 227989]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131767 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 232899]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
131769 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Tip-TNF 243732]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 7
                    Reset counter: 246
                    Mileage: 147044 km
                    Date: 2023.03.31
                    Time: 00:03:19
                    Terminal 15: On
8531970 - Quiescent Current
          U1406 00 [008] - Too High
          [Tip-TNF 235570]
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 1
                    Reset counter: 31
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 11:12:55
                    Supply voltage: Terminal 30: 12.5 V
                    Terminal 15: OFF
Address 1B: Active Steering
Cannot be reached
Address 22: AWD        Labels: None
   Coding: 0101
1 Fault Found
16656 - ROD - Unknown Error Code
          - 00 [008]
Address 2B: Steer. Col. Lock        Labels: None
   Coding: 0101
1 Fault Found
          - 00 [008]
Address 34: Level Control
Cannot be reached
Address 3B: Sensor Elect.
Cannot be reached
Address 3D: Special Function
Cannot be reached
Address 42: Door Elect, Driver        Labels: None
Address 44: Steering Assist        Labels: None
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System
Cannot be reached
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 392 E    HW: 5Q4 959 392 B
   Component: TSG BFS       011 0032
   Serial number: 0000261032030
   Coding: 001400208001040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 44D14C0D6E1821FB373-8010
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 E    HW: 5Q0 959 811 E
   Component: FOND_FHSG_PSG  005 0007
   Serial number: 00000000000015127616
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 874 C    HW: 5Q0 035 874 C
   Component: MU-S-ND-ER    H41 0456
   Serial number: SKZAZ2T5246641
   Coding: 03231601FF00000051111201C08808002F0208C601208500CE
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 34311CCD3EB8917B873-8060
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 565 919 605 B    HW: 565 919 605 B
   Component: ABT_Std-2_Nav  H50 8120
   Serial number: SKZ6ZHT1612405
   Data medium:
   Subsystem 2 - Part No SW: V03 959 809 FT    HW: -----------
   Component: ECE1 2022  --- 1720
   Serial number: --------------------
Address 61: Battery Regul.
Cannot be reached
Address 75: Telematics (J949)       Labels:| 5QE-035-285.clb
   Part No SW: 5NA 035 284 B    HW: 5NA 035 284 B
   Component: OCULowMQBLGE  H17 0717
   Revision: --------
   Coding: 03231601EA421A0D3B1C9E020045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004044
   ROD: EV_OCULowMQBLGE_004_VW25.rod
   VCID: 3C2134ED16E8593B4F3-8068
Address 80: Batt. reg. aux. accum.
Cannot be reached
Address 84: Night Vision
Cannot be reached
Address 8104: DC/DC Converter HV
Cannot be reached
Address 8105: Unknown Address: 8105 (J518)       Labels:* None
   Coding: 000F0F060F
2 Faults Found
          U1400 00 [008] - -
          [Tip-TNF 204459]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 146889 km
                    Date: 2023.03.30
                    Time: 10:34:19
                    ZAT_pressed: On
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
12786207 - Databus
          [Tip-TNF 241778]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 31
                    Mileage: 146895 km
                    Date: 2023.03.30
                    Time: 10:40:13
                    ZAT_pressed: OFF
                    Driver door: closed
                    SPN_Byte 0: 00
                    SPN_Byte 1: 00
                    SPN_Byte 2: 00
End----------(Elapsed Time: 08:45, VBatt start/end: 12.1V/12.1V)-----------
Lot's of low Voltage errors, are these all "fresh" faults in the car?
Have you cleared faults and see now what remains?
not cleared. new battery fitted yesterday.
will clear now and produce new fault codes.............
I'm reasonably confident that most, if not all, of those will clear and not repeat for 2 or 3 years.
You may want to adapt the battery if you have not already done so?
Also @123ashleyp23 - This should only apply if your car has Stop/Start fitted.
NEW CODES AFTER CLEARING............................
Wednesday,05,April,2023,14:25:05:16365
www.Ross-Tech.com
01-Engine -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
22-AWD -- Status: OK 0000
2B-Steer. Col. Lock -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
   Revision: B4H25---
Readiness: 0 0 0 0 1
Cannot be reached
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
1 Fault Found
          C102D 00 [137] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
   Coding: 000F0F060F
Cannot be reached
Cannot be reached
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Revision: 00001K00
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Coding: 164DDD
   Subsystem 2 - Part No SW: 5Q0 955 547 B    HW: 5Q0 955 547 B  Labels: 5Q0-955-547.CLB
   Coding: 00885D
   Alarm horn:
Cannot be reached
   Coding: 0061450001
Cannot be reached
Address 17: Instruments (J285)       Labels:* None-SRI3
1 Fault Found
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
   Alternator:
20 Faults Found
          U1126 00 [009] - -
          [Tip-TNF 237744]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
131608 - Radio
          [Tip-TNF 237745]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 232876]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 232878]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          [Tip-TNF 243715]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          [Tip-TNF 243719]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 232885]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 222741]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          [Tip-TNF 223115]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          [Tip-TNF 243722]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U0101 00 [009] - -
          [Tip-TNF 232891]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 228402]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 228022]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 236727]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 236728]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          [Tip-TNF 270354]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 228029]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          [Tip-TNF 227989]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 232899]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
          U1126 00 [009] - -
          [Tip-TNF 243732]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 246
                    Mileage: 147185 km
                    Date: 2023.03.31
                    Time: 22:27:02
                    Terminal 15: On
Cannot be reached
   Coding: 0101
   Coding: 0101
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
Cannot be reached
   Coding: 050200
   Data medium:
Cannot be reached
   Revision: --------
Cannot be reached
Cannot be reached
Cannot be reached
   Coding: 000F0F060F
End----------(Elapsed Time: 08:33, VBatt start/end: 12.1V/12.1V)-----------
It looks a lot better, did this clear out your errors on dash/infotainment system?
Also the battery itself does still seem low (but diagnostic sessions will drain this) do you have image or details on what you fitted, and for bonus points, what was fitted before battery swap?
Its a halfords own battery (pic attached). Swapped 'like for like'as its under warranty.
Errors have gone from dash - but i fear they might come back not driven it yet
Do i have to code it?
Ideally yes just to speed up the "learning process"
It has a battery monitor, as you can see hanging off the negative terminal top left (Stop/Start)
Follow the guide posted, won't take but a few minutes.
Brand can be JCB etc, doesn't matter
Value that is important is "fleece" technology
Amp Hour rating is "70"
Serial number, just add +1 to value of last digit
ok many thanks!
will give it a go now.......................
you have been so helpful. i will post back on here over the next day or so see how it goes
1 minute ago, 123ashleyp23 said:
ok many thanks!
If you have a multimeter, then try to read Voltage after you have driven the car, and it has rested for 2hrs (ideally overnight)
Unlock car, open bonnet and do a read, you would hope to be seeing 12.5V (with a little tolerance of that value)
Or just drive the car, and monitor it for a bit to see if it behaves better now.
Good luck!
Your CAN gateway is a right mess... Has it been swapped or replaced at some point?
I would be tempted to sort the installation list as it's expecting lots of modules that aren't present.
Not replaced or anything ... would you suggest replacing ?
I did notice that your version of VCDS is way out of date. I would suggest that you update it to the latest version, 23.3.0, and try the scan again.
Also have you changed any settings using VCDS?
No settings change only coded battery
 Still the same loughts pop up... I'm assuming after a certain amount of miles that will go ? Ice dome 60 miles so far
Your autoscan is full of 'Status: Cannot be reached 0100' errors.
This is because your CAN gateway has been coded to say that module is present but it can't communicate with them.
You should go through the installation list and remove any that are fitted to your vehicle.
Did you mean "are NOT"?
Could I not just change the can gateway box ? Like for like
If it's not broken, this would be like throwing money on the floor, and you would still need to code in a new one.
So you are best to update your software (if a clone, this could present problems) and do a fresh scan.  You also have other SW tool, so you could scan with that, and see what you have.
I have odbeleven.. will publish results later as I'm.not sure what I'm looking at
Everyone's help is greatly appreciated
You are trying to find out what hardware (control units) your car has installed.
Then you can use either software to code out (remove) the control units that don't answer (as they don't exist)
That's the theory!
