Skoda Octavia mkiv 1.5 tsi dsg 7 reverse brake noise
Hello ,
I have the Skoda Octavia 2021 1.5 tsi and from the first miles in reverse gear while braking it does a noise like a bloody cow moooooing
what can I do to get rid of this
here is the video
A well known issue with cars throughout all the main VW group marks. Has happened on two of my carss - SEAT and SKODA, both had their brake pads replaced under warranty. If however you're saying it's happened from day 1 on your 2021 car and it's now mid 2023 then think yourself fortunate if they put this through as a warranty repair as they'd be well within their rights to claim wear and tear.
did you solve the problem with the replacement of the brake pads or did the sound appear again after several kilometers?
because I told them from the first miles and they refused to change the pads because they said that it’s a high possibility to have again the same issue because of the material that the companies use nowadays
Yes, it solved problem both times. Many people had their pads replaced, I'm not aware of the problem not being solved.
You took your car back within the 1st 6mth of the car being registered as new, and that's what they said. Are you sure? How odd, I've never heard anything like it. Effectively they're saying that if something is faulty then they won't replace it as the replacement might be faulty.
Pity you didn't ask this forum for advice back then.
Unless you can prove that the fault was reported and that's what you were told then as I say, there's little chance of this being put thru as a warranty claim. If you replace the pads then my advice would be to have a non-Skoda garage do this and not to use the same pads as Skoda use.
Of course it might be something else causing the problem but you're saying Skoda checked the car and found nothing wrong?
Edited by kodiaqsportline
Yes they checked the car and they said that the material that Skoda use nowadays can cause noises and if they replace the pads the noise might be the same or it will start after some kilometers to do the same noise
