Alternator problems
Hi, and thanks for all help.
My Fabia Mk2 2012 1,2 tsi have a problem with the alternator. Or?
12v about batteri when car is running, and about 12v stopped. Batteri lamp is coming on in the dashboard.
I measured about 4,8v on the alternator.
I know replaced not just 1 but 2 alternators, the first one was used, so i thought it was bad, i decided to replace it with a new one! Still same problem!
No i checked the 2 small wires from the connector on the alternator, 1. To the ECU, made a bibtest, no problem.
And the other wire a blue one, goes inside the cabin to the BCM, made also a bibtest.
Does the BCM controls the alternator to produce power? I mean if the BCM is bad, so the alternator not will produce power?
Sorry for my English, im from Denmark, and found this forum? Maybe im lucky.
