Power wire routing.
Hi all just a quick one. I need to route a main power wire direct from battery to boot is there any entry point from fire wall hidden or bunged that I can use as wire access ???
Through the grommet with the rear screen wash pipe 👍. Beside the ABS pump.
Wullie.
Ah cool so that follows right down inside kick trim yes ???
Yes. Can't remember but you might have to remove glove box .A few screws for better access.👌👍
Yeah that's cool had it off before thanks for the info 👍
that was an absolutely perfect entry point cheers for the heads up :)
