No air blowing after air con blower fan replacement? 2012 Superb 118 TSI Dual Climatronic
Hello Superb people
The fan in my 2012 Superb Ambition 118TSI air conditioner (Climatronic dual zone) stopped blowing (no sound no air)
My local auto electrician/aircon specialist couldn't source a genuine Skoda part so they replaced the blower with a 3rd Party Passat blower fan
The fan is now working (you can hear it blowing away furiously) but no air comes through the vents (no air either for hot or cold)
The auto electrician is at a loss but thinks it may now be an issue with the blend door or other flap actuator?
They have suggested it may be a $1500 fix needing to take the dash off..
Has anyone had this issue before?
Is a multi part failure common? (blower Fan and blend door or other flap actuators?)
Does the dash need to be remove to service the system?
Just want to see if this sounds legit or if I should get a 2nd opinion?
Located in Brisbane Australia.
I think my first option would be to remove the pollen filter and see if it’s intact/misfitted or causing an obstruction in some way. The system should work as normal without the filter installed I believe.
Thanks for the tip, I’ll try that👍
I tried doing the calibration/reset by holding the AC and face buttons but no difference
I'd be inclined to check for any connectors that weren't reconnected during the blower replacement. It's an easy thing to overlook.
