fault cant turn off with key lights on on dash
hi this car is now doing my head in  Octavia mk2 2010 1.9 tdi 4x4 46000 miles light on dash ,and doesn't turn off with key ,two new ignition switches no difference, auto electrician later been through most of the car boot etc checking door locks unplugged most of boxes pulled all relays out nearly all fuses   etc , i have the dash checked all ok, really stuck on where to go from now no wet in boot   vdds no fault codes apart from when you unplug the battery been thru most forums but no luck please help no more ££££££ to fix i can use the car but have to pull a fuse or stall to stop then disconnect battery
i can't believe no one can help me disappointed with this forum
Firstly I’d suggest the forum is a community who help each other and are not an on demand service. Be polite and patient you may get help.
if you want on demand, it’s a garage you need to speak to.
Second, please read the forum guidelines before you carry on posting.
Thirdly and in response to your question, which fault light is on and have you had the car scanned with a dealer tool, vcds or similar. If so what was the fault code. If not that’s the only place to start. 👍
My guess would be a dodgy fuel shut off solenoid or anti shudder valve but as above it would be best to get a scan before anything else
