Indicator stalk replacement
Hi, I've replaced the indicator stalk with a used one on my Mk2 Octavia as the original stopped working. The original had cruise control which worked and the replacement does however this is the only feature to the replacement that does not work. Is it just a case of using VCDS to enable it to work? Any guidance will be appreciated.
