New Stereo/Speaker system?
Hey so I need a new stereo and speakers , current stock stereo is scratched and sometimes will just play up, any recommendations for new stereos that will fit an '05 Fabia? If they've got Bluetooth that would be great. I found a couple pioneer ones but I worry they are too big so just need one that is the right size really. And the speakers are just knackered to be honest, they both sound like they have no bass and when I bought the car they were 100% better, so if anyone knows the size of the Fabia's speakers or has any good recommendations for those would also be greatly appreciated, cheers.
I got a JVC mechless. It's very short behind. No real problems with cables. I did have to buy an aerial booster to keep the radio aerial working. Mine just sits there with a short USB stick plugged in. Also need a fascia trim, either Skoda or Connects2 etc.... To tidy up when the OEM is removed. You'll have a gap above it otherwise.
Simplest speaker option is to cut the cones out of the originals and use the frame/stand-off as a mount for new co-axial speakers and disconnect the existing tweeters (if fitted) behind the mirror covers. You may still need a shim or spacer to clear the window mechanism rail that passes directly behind the panel. If you know what you're doing, fit components. 160-165mm, up to 60mm depth.... Though the skinnier, the better. Can get Phoenix Golds that are 46mm deep.
