Traffic Sign Recognition System Prblem
Hi people. I have a problem with the system,  that is to say all speed values are wrong. For excample in my country highways’ speed limits are variable but minimum 120 km/hours. But, my car read 30, 50, 70 etc. So everyting is wrong.  My car is not a car which has this system added st production; it is added via a programme. Is there anyone has a experience and information.
Also, the person who made programming  said that if TRS is working other 2 function works without any setting. But i can not check wheter pedestrain recognition system and bicyle recognition system. I cannot find  menu or setting on the columbus. That is to say, i cannot be sure whether systems work  or not. How to check all these systems.
Did you try a GPS map update?
If I don’t make mistake the TSR uses both A5 camera and GPS map data to display speed limits. 🤔
Actually in my country we do not  have maps  in columbus, that is to say the map does not come with car pre-loaded in factory. So i have a columbus without map. As far as i understood you actual  problem is i dont have map.
That’s possibly the explanation.
What is your country?
Edited by Bap33
