Can I activate Adaptive Cruise Control?
I'm wondering if I could somehow activate Active Cruise Control on my Superb III?
Here is what I have in module info (source: CarScanner ECU info):
Could anyone tell me if it's possible with CarScanner Pro and how to do it? Thanks a lot in advance for all advices.
13. Active cruise control
Manufacturer spare part number: 3Q0907572C
Manufacturer ECU software version: 0195
Manufacturer ECU hardware number: 3Q0907572C
System supplier ECU software version: 1037603362;PF_R22.6.0_VW.MQB_B.MRR.0195.I3.2;0;Compiled by bno2bp on Thu Apr 21 14:48:33 2016$!
System name: ACC BOSCH MQB
Calibration repair shop code or equipment serial number: f,Q
Calibration date (ASCII): 190208
ODX file id: EV_ACCBOSCHVW48X
HW ver.: H04
ASAM ver.: 001009
Application software identification (id/version/valid/plausible/used): 7200/V001/1/1/1;
Programming date (HEX): 3351303930373537324320
Calibration date (HEX): 190208
Long Coding: 2A00600111FFC428949C8045
SWaP list (Unlock code: available/Cancelled/Individualization valid/Prerequisites met/Configuration normal/Functionality available/Authentification valid):
10003100: 0/1/0/0/1/1/0
10003200: 0/1/0/0/1/1/0
10003300: 0/1/0/0/1/1/0
10003400: 1/0/1/1/1/1/1
10003600: 0/1/0/0/1/1/0
10003700: 0/1/0/0/1/1/0
10003800: 0/1/0/0/1/1/0
It would need to be done with odis or vcp as you need to upload some hacked software to the module to allow you to enter new swap codes which haven’t been authorised by Skoda.
This doesn’t include the steering wheel stalks that need replacing also as well as a bit of coding in a few other modules.
Thanks @ApertureS
Seems too complicated for me now.
Edited by msemafor
