problems after installing a tow bar
Hello,
I just installed a tow bar with cable from ECS ( ecs VW146D1 ).
So after installing everything on the car, the car was a bit of a christmas tree with al the lights and faults.
i began to code the car.
CAN gateway - Enable 69-Trailer
BCM - Controller 09 - Enable Byte 1 Bit 1 - Trailer Hitch control module installed
Engine - this may vary between engine types - Enable Byte 5 Bit 4 - Trailer installed
ABS - Adaptations - change Vehicle & Trailer Stabilisation to Activated
Park Assist - Byte 3 - Change to 01 Trailer Hitch Installed (manually removable)
Byte 1 - Set to 01 - Trailer connector diagnosis active
then there was Trailer - Byte 3 - Choose the appropriate option , but i does not open the trailer menu, so i cant code this one.
but now after coding everyting the car stil has a phew faults that dont go away.
so i made a log of the faults ( it is in the attatchment )
is there someone that can help me diagnose the problem.
kind regards
lorenzo
Log-1XUR334-TMBJU7NE1K0132922-50268km-31235mi.txt
The car is not picking up module 69 -trailer.
Have you checked for power, ground, canbus at the module?
And  are you  sure that module is even suitable for the car, ive personally never heard  of it.
Sorry i totally forgot about the post i made.
I called the dealership to bring the car in so they could fix it.
When i drove the car for like 200 meter i started to notice that some lights go out.
And the dash gave me a fault for start/stop system.
I parked the car on the side of the road and turned ignition off, waited a few seconds and turned it back on.
All the lights where gone.
Drove back to my house and plugged the VCDS cable back in.
Most errors where gone and after a clear DTC i had no errors left.
So i don't know what happend there butt yeah it's fixed 😅.
ECS is a dutch company that makes cable's for trailers.
It is a well known company, but i am not sure if they ship there cable's across the world.
So it is normal that you did not heard of it.
Thanks anyway 👍
