Sunroof coding OFF
Hi!
I'd have to have sunroof some how to not to open at any situation because of lightbar at the roof. Otherwise if it opens, the light bar would break the glass panoramic sunroof.
So, is it possible to code sunroof of with VCDS (and if so, how)? Panoramic roof could still be useful and nice but not the sunroof 🥴
Skoda Octavia III fl 2020
Removing the power lead to the motor seems to be more foolproof than trying to code something almost nobody else in the world has done.
The sunroof is on the canbus network so you would either have to remove power from the motor or the sunroof controller.
Coding it out would be a bit of a pain and even then youd  need to just disconnect it after.
Or even easier, pull the fuse?
Coding out is simple if my factory Bluetooth module was anything to go by.
I got fed up with messages coming up on the MFD saying it was trying to connect with previous owners phones, I failed miserably trying to remove the old phones and add my own, not that I really want or need the connectivity while driving. Then I fitted a Chinese head unit so the OE Bluetooth would not have worked anyway.
All I needed to do was remove the BT module from the "Installed Modules" list and then disconnect it, if you dont do the latter you get fault codes saying that the now unknown module is trying to communicate with the Mother Ship 😄
