Needing help on my Skoda rapid
Hi there a have a Skoda rapid 2014 a had the a/c on today and now the heater spead or the a/c is not turning in now can anyone give me tips or advice on how to get it working
Welcome.
Looks like you need to go to someone to find out what is wrong first.
Has the AC ever been serviced?
Is it just the fan speed that has stopped working?
The fan speed has stopped and the botton for the a/c don’t light up anymore
OK @Satta - so we can help you, we need you to answer any questions we ask.
Again. Has the AC ever been serviced? And if so, how long ago was the last AC service (not your car service, unless they serviced and regassed the AC at the same time).
Does your Rapid have manual air conditioning or climate control?
Have you checked and replaced the fuse for the AC system (correct fuses for your year of Rapid is fuse 9 (AC Compressor) and fuse 39 (fan blower) the locations are listed in your manual and the fuse box is located under the steering column rather than in the supplementary fuse pack on top of the battery.
If it’s not the fuses or no AC gas, then you’ve burnt out one or more relays. The parts are cheap but difficult to install. Get an auto electrician pro to do it or a main dealer.
Hi there am not sure if the a/c has been serviced as a just not long bought the car.a will check the fuses in the morning and touch wood it’s only a fuse thank you and Al let you know how a get on
Fastest/cheapest way to get a diagnostic then would be a mobile a/c service or Kwik Fit's "N Colder or you don't pay" offer. I leave sorting out exact details to you since you know your exact postal address.
Eh14 3bl
It was the fuse the 30 amp fuse that blown
