Scary electrics
Driving my mk3 octavia  2lt 65 plate and all the electrics started to bleep and  the abs and esp warning lights ,and low tyre pressure light  came on Amber try to rest the tyre after checking  and it wouldn't reset.ive plug my odbe reader in and there was no codes . People have said it could be the battery on the way out ?? But looking for advice before taking it to skoda
Edited by jimbob6512
Dying / dead ABS sensors can give you these kinds of unhelpful error messages. VCDS scan may find that error code. Battery voltages are an easy check to give you a feel if the battery is the issue.
Agreed, almost certainly an ABS sensor and VCDS will find the error code if it is that, as all those systems are interlinked it could be several other things but VCDS will identify them, the most likely cause is an ABS sensor, one of mine played up recently after I had clipped a kerb with a rear wheel, it happened maybe 15 seconds later and would recur intermittenly becoming more frequent until permanent.
Thanks I'll get the volt meter on the battery to check it out as it's the original battery
I've got a full set of sensors in my garage which I bought when I had a wheel hub replaced just incase they were required
