Change Swing Radio to New Screen OEM 5ja919604b
Hi to all i am an owner of Rapid Spaceback 2015 and i am having an issue changing the classic Swing Radio 2014 to new Oem Screen With code 5ja919604b.
The old Radio has the classic cable on the back with many cables fit in a big black Jack (i will attache picture) and the new one has just a simple Jack with 12 pins.
I asked the local Skoda if  the OEM Screen 5ja919604b could fit in my car the definitely said yes but now its impossible to connect it 😔😔 ..
Is there any adapter from.classic to the new screen?Does anyone made this Update in his Rapid ?
I search today in eBay etc  and only found this for the universal Android Screens,is possible to work also in mine?
https://wavehertz.com/shop/automotive-accessories/car-electronics/stereo-coupler-wire-harness/skoda-rapid-canbus-wiring-harness-for-android-stereo/
I will be much appreciate any comments or ideas.
Chris.
  • 4 months later...
Chris.
hey there you cant fit that because your unit is with the computer and if you want to fit that screen you will need car with diffrent platform, glovebox and mib2 unit.
  • 8 months later...
If you dont need carplay you can use 5Ja035871C-D. But there will be CP problem. After deleting the CP, you can use it without problem. I already using it with this way
