Octavia 1.9 tdi Climate control Heating
Hi Guys i need your help please! i have a 2009 skoda octavia 1.9 tdi. it has climate control. i have a problem with the heating. The heating only gets hot on high heat setting... anything below 26 degrees Celsius is coming out cold? any ideas what this could be?
I have a 2009 with elegance trim and its the same. I have 3 years and its always been that way.
Ideally the system should be used in auto mode and then you can regulate the temperature using the temperature settings ie set it at 22 degress and leave it there.
Being my first car with climate control rather than just manual air con, the Climatronic controls arent the most user friendly.
Generally once the car gets up to temperature i leave the blower on at the lowest speed of off altogether.
