Front wipers won't turn off
Hello all
Not sure what's going on here but the front wipers are on all the time.  Speed selection seems to be not working either.
Is this most likely a stalk issue or something awry with the position sensor?  Either way help would be very welcome!  I've been lucky for two days with no rain and the fuse pulled out but it won't last...
Tia
Justin
Relay within onboard supply control unit welded its contacts in 'on' position at a guess.
That's easy enough to test even if it's a bore to strip out the trim panels and exit the bcm.  I fear that my soldering irons and hot air station are in packing boxes so may have to resort to a heat gun from Screwfix...
Number 1 rule of relay faultfinding:
Give it a beating first!
Unfortunately getting to it to hit it will take some time.
Miles easier on 9N Polo equivalent, but I doubt that's any help!
Edited by Breezy_Pete
