vag-com beta 606.5 out.
http://www.ross-tech.com/vag-com/download/beta/current.html
this is just a beta version for now. New features include:
Advanced Measuring Blocks Function
Freeze-Frame Data shown In-Line
DTCs indicate whether the MIL (Malfunction Indicator Lamp) is on as a result of this DTC
Automatic Detection of Installed Modules in Auto-Scan
Auto-Scan includes Hardware Part Numbers
Supported Codes function
EDC-15+ Mileage
Automatic Acceleration Measurements -- Performance Calculator
Regular and Long Coding functions combined into one screen
New version 1.9 VAG-Scope compatible with Advanced Measuring Blocks
New version 1.4 TDI-Graph compatible with V6 TDIs
Support for separate labels for Basic Settings
New Measuring Block Formulas
New Control Module Addresses
Updated Label Files
Compatible with all the latest models
Generic OBD-II now includes Info Types 08 and 0A in Mode 9.
More detailed info on the Ross tech site.
Will only work with windows '98 or newer until full release and will only work with the HEX and KEY interfaces.
Very good update. Just one question, what module is the most accurate to take the acceleration readings from?
The one from which you get the highest sample rates - in combination with turbo mode this is usually the ECU.
Now updated to 606.5.
