ESC fault when starting
Please help!!!
Only had my fabia 4 years
68 plate 1 litre Monte Carlo
I have a problem when starting in the mornings
all lights come on engine will try to start then shut off
warning for ESC comes on then tyre pressure then sometimes battery and other warnings
engine light will sometime stay off and go on
I’ve had it looked at by a mechanic - he replaced the battery as this was running low - he has advised to to go an electrician
does anyone have any idea what the problem is and if it’s worth fixing or getting rid ?
I presume this didn't solve the problems?
Did the new battery get coded?
What fault codes did the car have?
Thanks. AG Falco
