Driver’s window error
Hi!
I have this error in Vagcom and I don't know how to fix it. The window goes up and down, but the comfort option (one touch up or down) does not work. Does anyone know how to solve it?) thanks in advance.
Address 42: Door Elect, Driver       Labels: 5QX-959-X93-42.clb
Control Module Part Number: 5Q4 959 393 E    HW: 5Q4 959 393 B
  Component and/or Version: TSG FS        010 0031
           Software Coding: 001000208000040000001100
            Work Shop Code: WSC 21626 000 1048576
              ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 (SK37)
                       ROD: EV_DCUDriveSideEWMAXCONT.rod
                      VCID: 458B0CD6C4A1EFA5F1-8010
1 Fault Found:
65588 - Motor for Window Regulator
          B1487 54 [009] - Missing Calibration / Basic Setting
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 205974 km
                    Date: 2023.11.05
                    Time: 00:56:19
Hold the window in the up position for 2 seconds, then put it all the way down, hold the window in the down position for 2 seconds.
Sorted :)
Thanks so much. I followed your instructions and I dolved the issue. 😊
