Steering Wheel Sensor G250 VCDS fault code suggestions
Davidmb
Recommended Posts
I have a fabia 07 1.2 with the power sensor fault.
Address 44 Steering Assist Component Lenkhilfe TRW coding 10140 v270
30-10 Open or short to plus
I have checked continuity of cable cleaned plugs with Isopropyl.
Checked battery voltage (12.5 without alternator). Is only a 40ah battery but battery seems to keep charge. Although visible dimming on headlights when turning power steering.
Removed sensor (to figure out part no) which is:
6PD 008 847 00 or 6Q0423445
Symptoms: occasional loss of power steering and fault code persistence.
My question is does this sensor ever fail - as circuit board looked pretty sealed and clean or is it always more likely a failed pump? Or something else I could have missed?
Edited by Davidmb
Extra detail
Link to comment
Share on other sites
Here is some more information:
Turning steering wheel I get no changes in Steering Aid Sensor angular velocity:
https://drive.google.com/file/d/1f9RPT7gXniQSG_6CEKJTBslHIr3-T1bY/view?usp=sharing
Steering aid sensor voltage too low:
Pump voltage increases when turning steering
https://drive.google.com/file/d/1itqgXNLw3cZfoNR4KlQ-IWM-gCY4--cY/view?usp=sharing
Fault code shown: (Also clear no voltage):
https://drive.google.com/file/d/1XUJ0iTY5T4hL7CrgCcfjjkv3mfyKd5Bv/view?usp=sharing
So the question is, do these symptoms suggest a failed sensor or pump or can they be symptomatic of both?
Edited by Davidmb
Extra detail
  • Like 1
Link to comment
I would think it's worth trying another sensor before looking any further, since you've checked the wiring (presumably not seeing any signs of water ingress or corrosion at either end of cable?)
  • Like 1
Link to comment
Thanks for reply.
Ok cool re sensor, I ordered one last night but was trying to do some early prep in case it's the pump (or for when that arises...).
Don't suppose you can get a pump part number from VCDS? I was lucky getting the sensor part number tbh. Or maybe I can get a pump to match the sensor?
There were signs of some water near over the pump connectors but I cleaned them thoroughly with isopropyl and compressed air - and no corrosion at all.  The angular sensor and the void was clogged a bit with limescale though.
The only other electrical fault is a HVAC 01317 Control Module in Instrument Cluster and a temporary shaking speedo at zero (for 20's) - I am going to check the main earth points but think its unrelated to this issue.
Obviously will update my findings.
Link to comment
Pump part number is shown on your last image 6Q0423156AB.
I think the bits where it says reference voltage too low are a red herring, only relevant if the steering were the Koyo version which has a four-wire G250 sensor and a reference voltage associated with that.
Link to comment
  • 5 weeks later...
  • 4 weeks later...
Hi i have skoda octavia combi 2010 1z5 with this module address 16 steering wheel
1K0 953 549 CF
Component: J0537   056 0111
Coding:Shop #:73430 790 00000
VCID: 78FF5DE70BD3424D7B-802C
This is information for my module
 Control Module  Part Number =
  1K0-953-549-CF
Slip Ring   =    Type 2
Software Level     =       SW 0111
Variant   =  Highline
Steering Angle Sensor = NO
LIN Version = 2.0
Notrs =#2
Steering Wheel Control Module Versions for Volkswagen
(Ross Tech information)
 A hyphen or "-" means No
 TBD: We do not have information on the configuration at the present time.
 Slip Rings
o Type 1: 1K0-959-653 and 1K0-959-653-A
o Type 2: 1K0-959-653-C and 1K0-959-653-D
 Software Level
o This can be checked in the Component Field of the Open Controller
Screen
 Variant
o Lowline: No additional Options/Features
o Midline: Cruise Control, Board Computer
o Highline: Cruise Control, Board Computer, Multi-Function Steering
Wheel
 Steering Angle Sensor
o Yes: The Steering Angle Sensor (G85) is installed directly at the Steering
Wheel/Slip Ring.
o No: The Steering Angle Sensor (G85) is part of the Electro Mechanical
Steering Assist.
 LIN Version
o The LIN version number should be shown
o - means that LIN is not supported by this controller
 Notes:
o #1: Does NOT allow Cruise Control Retrofitting, in such a Case you need
to replace the Steering Wheel Control Module.
o #2: Manual Transmission only, does NOT support Ignition Key Lock.
This is for vcds coding
What vcds coding is for my module
0?xxxxx: Driver-Assistance-Systems
0 = Driver-Assistance-Systems not installed
0x?xxxx: Vehicle Type
0 = Normal
1 = Special Purpose with Multi-Function Control Module (Steer. Column. Contr. Mod. as Master)
2 = Special Purpose with Multi-Function Control Module (Multi-Function Contr. Mod. as Master)
0xx?xxx: Transmission
0 = Manual Transmission
1 = Automatic Transmission
0xxx?xx: Multi-Function Steering Wheel (1-4 LIN1.3 / 5-8 for LIN2.0)
0 = Multi-Function Steering Wheel not installed
1 or 5 = Multi-Function Steering Wheel w/o Tiptronic and w/o Push-To-Talk (PTT) installed
2 or 6 = Multi-Function Steering Wheel with Tiptronic and no Push-To-Talk (PTT) installed
3 or 7 = Multi-Function Steering Wheel w/o Tiptronic and with Push-To-Talk (PTT) installed
4 or 8 = Multi-Function Steering Wheel with Tiptronic and with Push-To-Talk (PTT) installed
0xxxx?x: Cruise Control System (CCS) and Adaptive Cruise Control (ACC)
0 = Cruise Control System (CCS) not installed
1 = Cruise Control System (CCS) with 6 Positions via separate Stalk installed
2 = Adaptive Cruise Control (ACC) with 6 Positions via separate Stalk installed
3 = Cruise Control System (CCS) with 4 Positions via Blinker Stalk installed
0xxxxx?: Rear Wiper and Board Computer
1 = Rear Wiper not installed / Board Computer via Wiper Stalk not installed
2 = Rear Wiper installed / Board Computer via Wiper Stalk not installed
3 = Rear Wiper not installed / Board Computer via Wiper Stalk not installed
4 = Rear Wiper installed / Board Computer via Wiper Stalk installed
Help me for coding number
Link to comment
4 minutes ago, humaxman said:
Ok im sorry
Not a problem just a different sensor and a different strategy. Hence new topic. Regards.
Link to comment
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
