Rear window defrost
Hi can someone help me here, i tried to search on forum i found posts but no one didnt mention how to fix it.
My rear window defrost is not working,when i turn it on the light on switch shut off after 1sec and Relay does not operate.
id i turn it ON with diagnostic relay clicks and and defrost work normaly- but only with diagnostic. Can anyone help ?
When you turn it on with diagnostics does it actually heat?
The defrost button light going on then off usually indicates that the heater element isn't taking enough current.
Yes when i turn it on with diagnostic it actualy heat
Anyone have any idea?
If there is an issue, it will throw a code.  Can you get a code scan done?
Hello no i didn get any code, today i fixed it i tried to reset all values on 09 central electronic and now it works if anyone would have the same problem ,but i dont know what coused the problem.
