Felicia's have blower motor relays?
Hi guys,
When adjusting my blower motor speed I only have 2 out of the 3 blower speeds, when I turn the dial what I get is at: -
0, the blowers off
1, what seems to be speed 2
2, speed 2
3, speed 3
So it’s not drastic but I would like to have speed 1 just blowing lightly. Do I need to replace a resistor (is there one?) if so where is it and which one if not is it a motor or switch issue?
Regards Rob
It's 1.9D, right?
Those use different heating from Favorit, so I'm not familiar with it. But you should be able to locate the resistor pack in the engine bay, following wires from the motor.
There are two bimetal contacts that appear to short the resistors if they overheat. It's possible that the one for 1st speed got stuck.
1658_odpor-topeni-predradny-favorit.jpg?
I’ve had a look in the engine bay and the only thing that side of the firewall is what I would consider the motor for the blower (the bit to the right of centre) but if some could confirm this I would appreciate it?
Yep, that's the blower motor.
I dug up the service manual, the resistor pack is on the side of the heater box, right behind the blower fan. (Part marked with 8 on the pic below)
You can see wires from the motor leading to it.
Edited by Papez
Thank you for that, I’ll dig that bugger out in the morning.
I think the part's code is 6U0959263A (blower motor resistor)
and 6Q0959263A (fan-heat resistance).
Hi,
I’ve had a bit of a result with this today. I got in the engine bay and as Papez diagram shows it was there behind the intake, two tiny screws and it was out. What I found was the one contact was touching so with a blast of electrical cleaner and a light flick up and separate the blower now works as it should.
RESULT 🎉🥳🥂🥂
