Do you need to reprogram ABS module if you only replace hydraulic unit
trabolgan
Recommended Posts
Morning all - I have the task fitting a new ABS module on my 2011 skoda octavia - at first I was looking at the repair kit below but found none about.
Repair kit 1K0 698 517 B  Suitable as a replacement for the hydraulic blocks:
1K0 614 517 B, C, D, E, H, J, M, N, Q, T, AA, AB, AE, AF; 3T0 614 517, 3TO 614 517 A and 2K3 614 517
So I decided to buy a tested full unit exactly the same as what's on my car 1K0 614 517 AB - on my replacement new part can I remove the connector block from the hydraulic block removing the 2 screws in affect  creating a repair kit and just replace the hydraulic block/pump? and does this remove the need for programming?
I am hoping to get this done this week, the fault is traction control light stays on and diagnostics pointed at ABS module 100%
Any advice would be greatly appreciated
Thank you
Link to comment
Share on other sites
Create an account
Register a new account
Sign in
Sign In Now
  • Community Partner
  • Create New...
