DSG error P176F00
I have a problem with the dsg gearbox on my 2013 Skoda Octavia car. The gearbox has 7 speeds. When the car is cold and doesn't drive for two days, it occasionally reported an error on the gearbox. we read error p176f00. in the service center they say that the lamella is worn out and recommend replacing the clutch and flywheel. the car has traveled 260,000 kilometers. Is this the standard mileage for replacing the lamella and is it risky to do this because I read that there is a possibility that after this repair the problem will be even worse.
Sounds like the DQ200 DSG has done quite well getting to 260,000 km / 161,500 miles.  16,000 miles a year and no servicing required is OK imo.
 It would very much depend on how used what anyone might expect as a standard mileage.
What engine does your car have?
What does the professional that is going to fit the new parts say about their experience after they do the job and take your money?
I take it they will be changing both oils at the time since they have been there for 260,000 km.
The engine is 1.6. td. I would like to hear experiences after replacing the clutch. The problem only appears when the car is cold. I think it can last for sure like this for a year once the winter is over
