Damn stubborn dealer stickers!
Any recommendations for removing them easily and safely? I have two; one in the rear window and a circular one on the windscreen.
They seem particularly stubborn this time - as if the dealer would make them difficult to remove on purpose! :rolleyes:
try a stanley knife or razor blade but be bl00dy careful best way IMHO :D
Get some heat on them, very carefully with a hairdryer for example, if you're lucky they'll peel off in one piece ;)
Acetone. Thats how I got mine off, with no mess or scratching.
Chris
I use a flat edged blade, slide it under and lift up.
Just be carefull if you are removing a rear one that you dont damage the element for the heated reart screen.
Acetone does work, just nick your missus nail polish remover.
Rub some WD40 in to the glue and it beads up :)
Thanks for all the advice chaps.
Heat seems to be the key in removing them.
I removed 1x rear screen sticker, 1x round windscreen sticker, 1 x oversize tax disc holder and two other stickers from each rear passenger door window.!
My fingernails are stuffed with bits of glue and plastic and I got through about half a bottle of sticky stuff remover.
Looks much better now, with only my briskoda.net sticker taking pride of place on the rear screen.
