Skoda Enyaq and ESC coding
Hey!
I tried to code the Skoda Enyaq MY21 ESC On+ASR Off+ESC Sport/Off, but the coding failed. The hood is up, the electric handbrake is on and the "ignition" is on in the car. Is there any information on how to code this?
VCDS Auto-Scan log:
Wednesday,03,May,2023,17:07:59:00464
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 11 x64
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
Dealer/Shop Name: J.P - V3lmu
VIN: TMBJB7NYXNF009086   License Plate: SKODA ENYAQ
Mileage: 36787km-22858mi   Repair Order: 1. kierros
Chassis Type: NY-SKE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 17 19 23 2B 3C 42 44 51 52 5F 69 6C
          75 8C A5 C0 C6 D6 D7 8105 811E 811F 8120 8121 8123 8124 8125 C002 C003
VIN: TMBJB7NYXNF009086   Mileage: 36787km-22858miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
23-Brake Booster -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
3C-Lane Change -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
51-Electric Drive -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
75-Telematics -- Status: OK 0000
8C-HV Battery -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
C0-Act. for Ext. Noise -- Status: OK 0000
C6-Batt. Chrg. -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: OK 0000
D7-Light Ctrl Right 2 -- Status: OK 0000
8105-DC/DC Converter 12V -- Status: Malfunction 0010
811E-Burglary Protection FL -- Status: OK 0000
811F-Burglary Protection FR -- Status: OK 0000
8120-Burglary Protection RL -- Status: OK 0000
8121-Burglary Protection RR -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Malfunction 0010
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
Address 01: Engine (J623-EBJC)       Labels: 0EA-907-425-V1.clb
   Part No SW: 0EA 906 012 AT    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 1533
   Dataset Number: V03935352AT 0001
   Coding: 040200060364140070080000001000802008060000000000
   ASAM Dataset: EV_VCU00XXX0200EA906012AT 001003
   ROD: EV_VCU00XXX0200EA906012AL.rod
   VCID: 7DA7F9E3DD7173E264D-8028 SFD
   VINID: 91D49A4877A9A1E58000900818DAEF6EF1
   Selector lever:
   Subsystem 1 - Part No SW: 5LA 713 203     HW: 5LA 713 203
   Component: ZSB_SB_mono    H01 0014
   Serial number: 21 159 0221 0
   Radiator shutter:
   Subsystem 2 - Part No SW: 1EA 965 501     HW: 1EA 965 501
   Component: V711           022 0006
   Serial number: 20210518060604075134
4 Faults Found:
31949 - Front Camera for Driver Assist Systems
          U1229 00 [032] - Implausible Message
          [Front camera for driver assistance systems implausible]
          Intermittent - Not Confirmed - Tested Since Memory Clear
25575 - Camera control module
          U107A 00 [032] - No communication
43491 - Communication Authentication
          U3035 00 [032] - Invalid Signal
          [Communication Authentication Signal Invalid Data]
38468 - Implausible Data Received from ESP Control Module
          U0416 00 [096] - -
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: 1EA-614-517.clb
   Part No SW: 1EA 614 517 AA    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H15 0177
   Serial number: B005ELE         Dataset Number: V03935352LL 0001
   Coding: 1A9E54AC393B583F2A3C9CE622DF32A6484A6D266433114928444C651252B66426CC889214EECBBEFD0077D37DBF00
   ASAM Dataset: EV_Brake1ZFESCEPBMEB 013149
   ROD: EV_Brake1ZFESCEPBMEB.rod
   VCID: 71BFD5D391290782F05-8024 SFD
1 Fault Found:
16401 - Tire Pressure Warning
          C102D 00 [108] - -
          [RKA_DEM_MON_P_WARN]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 5
                    Fault Frequency: 25
                    Reset counter: 40
                    Mileage: 36160 km
                    Date: 2071.03.08
                    Time: 10:24:03
Address 05: Acc/Start Auth. (J518)       Labels: 5WA-959-436.clb
   Part No SW: 5WA 959 436 G    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: --------------- Dataset Number: V03935341NA 0001
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: 58E98877129376CA17B-800C
No fault code found.
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EA 907 727 R    HW: 1EA 907 727 R
   Component: Climatronic   H01 0383
   Serial number: --------------- Dataset Number: V03935351GA 0001
   Coding: 001022017020320010100010111001102000102100221001000000000000
   ASAM Dataset: EV_ACClimaBHBMEB31X 002007
   ROD: EV_ACClimaBHBMEB31X.rod
   VCID: 49CF5D33D9391F42985-801C
   Fresh air blower control module (front):
   Subsystem 1 - Part No SW: 1EA 820 021 A    HW: 1EA 820 021 A
   Component: J126 J126      002 0004
   Serial number: 00000000000000000995
   A/C compressor sub:
   Subsystem 2 - Part No SW: 1EA 816 551 G    HW: 1EA 816 551 G
   Component: J842 eKK       H07 0003
   Serial number: 1EA816551G14062130E3
   Humidity sensor: exterior:
   Subsystem 3 - Part No SW: 4H0 907 658 C    HW: 4H0 907 658 C
   Component: G935 MuFu      H05 0010
   Serial number: AB5D014E00PAG0MUFU04
   Auxiliary Heater Control Module/PTC 2:
   Subsystem 4 - Part No SW: 1EA 963 581 D    HW: 1EA 963 581 D
   Component: 0123456789012  010 0160
   Serial number: 5390220CA21179000325
   Interior temperature sensor:
   Subsystem 5 - Part No SW: 5WA 907 527 A    HW: 5WA 907 527 A
   Component: E857           H01 0103
   Serial number: 00002100621163443513
   Expansion valve 1 for refrigerant:
   Subsystem 6 - Part No SW: 1EA 816 681 A    HW: 1EA 816 681 A
   Component: N636 EV1_KaMi  003 0003
   Serial number: E1000000000001005433
   Expansion valve 2 for refrigerant:
   Subsystem 7 - Part No SW: 1EA 816 682 A    HW: 1EA 816 682 A
   Component: N637 EV2_KaMi  003 0003
   Serial number: E20000000000000074OI
   Expansion valve 3 for refrigerant:
   Subsystem 8 - Part No SW: 1EA 816 682 A    HW: 1EA 816 682 A
   Component: N638 EV3_KaMi  003 0003
   Serial number: E30000000000000074OI
   Carbon dioxide content sensor:
   Subsystem 9 - Part No SW: 4N0 907 658     HW: 4N0 907 658
   Component: G929 ICO2S     H04 0231
   A/C pressure/coolant temperature sensor 2:
   Subsystem 10 - Part No SW: 4N0 959 126 G    HW: 4N0 959 126 G
   Component: G826 pT-Sens2  H04 0002
   A/C pressure/coolant temperature sensor 3:
   Subsystem 11 - Part No SW: 4N0 959 126 H    HW: 4N0 959 126 H
   Component: G827 pT-Sens3  H04 0002
   Shut-off valve 1 for refrigerant:
   Subsystem 12 - Part No SW: 1EA 816 681 A    HW: 1EA 816 681 A
   Component: V424 AV1_KaMi  003 0003
   Serial number: A1000000000001005433
   Shut-off valve 2 for refrigerant:
   Subsystem 13 - Part No SW: 1EA 816 701 A    HW: 1EA 816 701 A
   Component: N640 AV2_KaMi  003 0003
   Serial number: A2000000000000006ZYR
   Shut-off valve 3 for refrigerant:
   Subsystem 14 - Part No SW: 1EA 816 701 A    HW: 1EA 816 701 A
   Component: N641 AV3_KaMi  003 0003
   Serial number: A3000000000000006ZYR
   Shut-off valve 4 for refrigerant:
   Subsystem 15 - Part No SW: 1EA 816 702 A    HW: 1EA 816 702 A
   Component: N642 AV4_KaMi  003 0003
   Serial number: A4000000000000006J9A
   Shut-off valve 5 for refrigerant:
   Subsystem 16 - Part No SW: 1EA 816 702 A    HW: 1EA 816 702 A
   Component: N643 AV5_KaMi  003 0003
   Serial number: A5000000000000006J9A
   A/C pressure/coolant temperature sensor 4:
   Subsystem 17 - Part No SW: 4N0 959 126 F    HW: 4N0 959 126 F
   Component: G395 pT-Sens1  H04 0002
   A/C pressure/coolant temperature sensor 5:
   Subsystem 18 - Part No SW: 4N0 959 126 G    HW: 4N0 959 126 G
   A/C pressure/coolant temperature sensor 6:
   Subsystem 19 - Part No SW: 4N0 959 126 H    HW: 4N0 959 126 H
   Rear air conditioning block 1:
   Subsystem 20 - Part No SW: 565 907 049     HW: 565 907 049
   Component: E265KlimaHeck  H02 0201
   Serial number:       06051501850797
5 Faults Found:
263681 - Exterior Air Quality/Humidity Sensor
          B137A 04 [032] - Internal System Fault
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 19
                    Mileage: 27618 km
                    Date: 2022.10.16
                    Time: 09:30:02
                    Outside temperature: 15.00  C
                    Voltage terminal 30: 13.70 V
                    System run time-Engine running time: 253 s
                    System run time-Terminal 15 on: 253 s
                    Air quality status: Initialization
524112 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
          [Lost Communication With Gateway "A" 19]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 35779 km
                    Date: 2023.02.24
                    Time: 09:33:57
1244969 - Control Module for HV-Heater
          B1581 F6 [032] - Temperature Protection Active
          [HV heater control module Malfunction 10]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 25774 km
                    Date: 2022.10.01
                    Time: 07:52:57
                    Outside temperature: 10.00  C
                    High-voltage air heater status: global-Requirement: not active
                    High-voltage air heater status: global-Specified value: left: 0 %
                    High-voltage air heater status: global-Specified value: right: 0 %
                    High-voltage air heater status: global-Center target value: 0 %
                    High-voltage air heater status: global-Number of heat zones: 3 zones
                    High-voltage air heater status: global-Heating system used: Heat pump
                    High-voltage air heater status: internal-Supply voltage: OK
                    High-voltage air heater status: internal-Timeout: OK
                    High-voltage air heater status: internal-Current: actual value: 0.00 A
                    High-voltage air heater status: internal-High voltage supply voltage: 434 V
                    High-voltage air heater status: internal-Response error: OK
                    High-voltage air heater status: internal-Vehicle high voltage system: OK
                    High-voltage air heater status: internal-HV heater: status: Power restriction due to hardware
                    High-voltage air heater status: internal-Supply voltage: actual value: 0.00 V
                    High-voltage air heater status: internal-Heater electronics and circuit board temperature (PCB): -50  C
                    High-voltage air heater status: internal-Heating circuit 1 status: OK
                    High-voltage air heater status: internal-Heating circuit 2 status: OK
                    High-voltage air heater status: internal-Heating circuit 3 status: OK
                    High-voltage air heater status: internal-Heating circuit 4 status: OK
                    High-voltage air heater status: internal-Current flow with heating circuit not activated: OK
                    High-voltage air heater status: internal-Total current over long period of time too high: OK
                    High-voltage air heater status: internal-Circuit board temperature: shut-off value: OK
                    High-voltage air heater status: internal-Internal error (other): OK
524091 - No Communication with Diagnostic Gateway
          U0146 00 [032] - -
          [Lost Communication With Gateway "A" 24]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 20
                    Mileage: 35779 km
                    Date: 2023.02.24
                    Time: 09:33:57
523548 - Engine Control Module
          U12DB 00 [032] - Received Malfunction Message
          [Engine Control Module (ECM) received malfunction 3]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 31126 km
                    Date: 2022.12.22
                    Time: 13:10:51
Address 09: Cent. Elect. (J519)       Labels: 1EA-937-BCM-V1.clb
   Part No SW: 1EA 937 089 L    HW: 1EA 937 089 A
   Component: SAM_H         H22 0130
   Serial number: 06102116800688- Dataset Number: V03935352JH 0001
   ASAM Dataset: EV_SAMVW31x 003001
   ROD: EV_SAMVW31x_003_VWE3.rod
   VCID: 47CB5B0BCF2DE9328E1-8012 SFD
   Wiper motor control module:
   Subsystem 1 - Part No SW: 11B 955 119 A    HW: 11B 955 119 A
   Component: FWISCHER_MYJT  003 0032
   Serial number: 907353F0402113600530
   Rain/Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 555 B    HW: 5Q0 955 555 B
   Component: RLHSS          054 0208
   Serial number: S6Y21M06D25H05M04S30
   Light switch:
   Control head for driving and comfort functions:
   Roof electronics control module:
   Subsystem 5 - Part No SW: 5H0 959 561 AR    HW: 5H0 959 561 AR
   Component: -VW----LINDA-  502 0813
   Serial number: MW3LND20052100010326
   Steering Column Switch:
   Subsystem 6 - Part No SW: 5Q1 953 507 GF    HW: 5Q1 953 549 F
   Component: J527 SMLS MQB  005 0080
   Serial number: 00000009062120241133
Address 10: Park/Steer Assist (-----)       Labels:| 1EA-919-294.clb
   Part No SW: 1EA 919 294 B    HW: 1EA 919 294
   Component: PDC08K------- H02 0208
   Serial number: 000019062194560 Dataset Number: V03935340FE 0001
   Coding: 0040014101
   ASAM Dataset: EV_EPHBO18VW3100000 002016
   ROD: EV_EPHBO18VW3100000_VWE3.rod
   VCID: 3B2337FB83E5BDD21A9-806E
3 Faults Found:
12648976 - Databus
          U1121 00 [032] - Missing Message
          [Steuerger t f r Aussentemperatur - Temperaturen_01 - kein Signal/keine Kommunikation]
13688835 - Databus
          U1123 00 [032] - Received Error Message
          [Steuerger t f r Rear Cross Traffic Alert - RCTA_01.RCTA_Status - Fehlerspeicher auslesen]
13959169 - Parking Sensor(s); Front
          B10FC F0 [036] - Function Limitation due to External Factors
          [Geber f r Einparkhilfe - Schmutz bzw. Eisbildung vorn]
Address 13: Auto Dist. Reg (J428)       Labels:* None
   Part No SW: 1EA 907 572 G    HW: 1EA 907 572
   Component: ARS510VW19 H02 0123
   Dataset Number: V03935345DL 0001
   Coding: 058300734071404512474000000040C5AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
   ROD: EV_FRONTRADARCONTIVW310_003.rod
   VCID: 3C2134E786EBBAEA133-8068
10 Faults Found:
196800 - Databus
          U1123 00 [160] - Received Error Message
          [VDY_FS_VEH_CORR_MONITOR]
          MIL ON - Intermittent - Not Confirmed - Tested Since Memory Clear
209054 - Databus
          [FAULT_BV_BLINDNESS_ERROR]
0578 - Databus
          U1122 00 [032] - Implausible Message
          [FAULT_APS_BLINDNESS_DETECTED]
1538 - Sensor for Automatic Distance Control
          C110B F0 [160] - Limited Visibility
          [FAULT_SENSOR_BLINDNESS]
1396 - Sensor for Automatic Distance Control
          [FAULT_SENSOR_NO_FREE_SIGHT]
204812 - Databus
          U1121 00 [160] - Missing Message
          [FAULT_TIMEOUT_EINHEITEN_01]
204815 - Databus
          [FAULT_TIMEOUT_FAS_ANZEIGEN_01]
1076 - Databus
          [FAULT_TIMEOUT_GRA_ACC_01]
1107 - Databus
          [FAULT_TIMEOUT_KAMERA_STATUS]
0536 - Databus
          [FAULT_TIMEOUT_VZE_04]
Address 15: Airbags (J234)       Labels: 1EA-959-655.clb
   Part No SW: 1EA 959 655 CE    HW: 1EA 959 655 CE
   Component: VW40Airbag    009 0366
   Serial number: V170VyE0DE3     Dataset Number: V03935350AG 0001
   Coding: 88CC008000F0C000000000200000000051540000A0540000C000F68000100065
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X.rod
   VCID: 0655960F88A7303A357-8052 SFD
6 Faults Found:
9634963 - Control Module for Front Left Belt Tensioner
          B1304 93 [032] - No Operation
1075464 - Databus
          [NWD: 0x0DB AWV_03 error value AWV_Time_to_collision]
1075461 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Objektstatus]
1075462 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_CW]
1075463 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_Kollisionsueberdeckung]
1075465 - Databus
          [NWD: 0x0DB AWV_03 error value SDF_PSF_v_rel]
Address 17: Instruments (J1254)       Labels:. 10A-920-320.clb
   Part No SW: 5LA 920 320     HW: 5LA 920 320
   Component: FAHRERDISPLAY 021 0520
   Serial number: 1G1X1084-514928 Dataset Number: V03935341GX 0001
   Coding: CE70
   ASAM Dataset: EV_DashBoardLGMEB 001027
   ROD: N/A (VIN: N/A)
   VCID: 72BDDADF942F3C9A09F-8026
No ASAM data for: "EV_DashBoardLGMEB" (SK35)
Address 19: CAN Gateway (J533)       Labels: 1EA-937-012.clb
   Part No SW: 1EA 937 012 L    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 065 0123
   Serial number: SJ8ICS200621117 Dataset Number: V03935351P  0001
   GVL: 2D0000000608D0CC8060904648180040C400400000020000000000000000DE47
   ASAM Dataset: EV_GatewICAS1MEB 005001
   ROD: EV_GatewICAS1MEB_VWE3.rod
   VCID: 392F2DF389D98FC2085-806C SFD
   Battery Monitoring Control Module:
   Subsystem 1 - Part No SW: 1EA 915 181 A    HW: 1EA 915 181 A
   Component: J367-BDMConti  H04 1073
   Serial number: 773861010021053104A1
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 5E3 919 719 E    HW: 5E3 919 719 E  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H02 0100
   Serial number: PR6-0440062168210555
   Steering Wheel Touch Recognition Control Module:
   Subsystem 3 - Part No SW: 5E3 959 542 J    HW: 5E3 959 542 J
   Component: KLR            082 0020
   Serial number: 3133273AB21158082903
   left tail lamp 1:
   Subsystem 4 - Part No SW: 5LA 945 207 A    HW: 5LA 945 207 A
063 0215
   left tail lamp 2:
   Subsystem 5 - Part No SW: 5LG 945 307 B    HW: 5LX 945 307 B
063 0215
   Right rear tail lamp 1:
   Subsystem 6 - Part No SW: 5LA 945 208 A    HW: 5LA 945 208 A
063 0215
   Right rear tail lamp 2:
   Subsystem 7 - Part No SW: 5LG 945 308 C    HW: 5LX 945 308 C
063 0215
28 Faults Found:
1049259 - Ethernet Databus; Branch 11
          U14A8 00 [036] - No Communication
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 7
                    Mileage: 31736 km
                    Date: 2022.12.29
                    Time: 15:39:20
2502759 - Ethernet Module for Emergency Call
          U1642 00 [044] - No Communication
          [Emergency-call_module_no_communication_vlan]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 13
                    Mileage: 31736 km
                    Date: 2022.12.29
                    Time: 15:39:20
8397062 - 12V Test Pulse Diagnostics
          P1A85 00 [044] - Not Possible
          [12_V_test_pulse_not_available_by_reason_of_EMHLR]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 13
                    Reset counter: 30
                    Mileage: 26346 km
                    Date: 2022.10.10
                    Time: 15:46:47
                    Reason for rejection: 1
                    Bad counter: 41
                    Test pulse counter not OK: 0
                    Counter increase not OK: 0
                    BZE_test_pulse_request: 1
                    BZE_test_pulse_result: 0
8397569 - Quiescent Current
          U1406 00 [036] - Too High
8397571 - LV Energy Management
          B1802 F1 [044] - Warning Triggered
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 46
                    Reset counter: 39
                    Mileage: 26069 km
                    Date: 2022.10.04
                    Time: 04:11:14
                    51
8540417 - EgoMaster
          U15FA 00 [044] - Input Data Error
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 46
                    Reset counter: 36
                    Mileage: 25717 km
                    Date: 2022.09.30
                    Time: 11:57:39
153102 - Control Module for Theft Protection; Front Left
          B1A61 29 [100] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 36757 km
                    Date: 2023.05.01
                    Time: 14:11:30
153134 - Control Module for Theft Protection; Front Left
          B1A63 29 [100] - Signal Implausible
8786912 - Control Module for Steering Wheel Touch Detection
          B17B8 F2 [040] - Sensor Malfunction
          [Control_module_for_steering_wheel_touch_regulation_malfunction_sensor_1]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 120
                    Reset counter: 30
                    Mileage: 28450 km
                    Date: 2022.10.21
                    Time: 04:24:10
8491266 - Secure Onboard Communication
          U14FE 00 [044] - Signature Verification Failed
          [SOK_signature_verification_failed]
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 42
                    Reset counter: 32
                    Mileage: 25723 km
                    Date: 2022.10.01
                    Time: 04:58:11
8511746 - Unknown Error Code
          U173E 00 [044] - -
          [Occupant_Presence_Service_Error]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 246
                    Reset counter: 39
                    Date: 2022.10.01
                    Time: 14:52:59
9371914 - predictive route data
          B1630 02 [109] - Signal Failure
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 40
                    Mileage: 25717 km
                    Date: 2022.09.30
                    Time: 11:42:19
9371915 - predictive route data
          B1630 02 [044] - Signal Failure
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 30
                    Date: 2022.10.02
                    Time: 22:05:45
8557314 - Databus
          U1122 00 [044] - Implausible Message
          [ZM_GNSS_Implausible]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 18
                    Date: 2022.10.13
                    Time: 20:01:43
1376305 - Control Module for Multi-Function Steering Wheel
          B114D F2 [047] - Implausible Message
          [Multi_function_steering_wheel_control_module_implausible_frame_lin]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 25717 km
                    Date: 2022.09.30
                    Time: 11:37:17
2494569 - Ethernet Module for Back-Up Cam
          U1643 00 [047] - No Communication
          [Rearview_camera_system_control_module_no_communication_vlan]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 25717 km
                    Date: 2022.09.30
                    Time: 11:37:28
8515632 - Emergency Charging Function
          P10BA 00 [100] - Active
          [HVLM_limp_home_plug_detection]
8515664 - Control Pilot
          P0CF4 00 [108] - Implausible Signal
          [HVLM_no_cp_communication_possible]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 56
                    Reset counter: 30
                    Mileage: 25723 km
                    Date: 2022.09.30
                    Time: 15:02:47
8515843 - Unknown Error Code
          B1ACC FA [108] - Unknown Error Elaboration
          [HVLM_timeout_charging_readiness_onboard_charger]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 4
                    Reset counter: 15
                    Mileage: 32179 km
                    Date: 2023.01.06
                    Time: 07:21:54
8515849 - High Voltage Coordinator
          B1AF9 F0 [108] - No Charging Approval
          [HVLM_high_voltage_coordinator_no_approval]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Reset counter: 16
                    Mileage: 32179 km
                    Date: 2023.01.06
                    Time: 07:44:02
8515856 - Unknown Error Code
          P1BEC 00 [108] - -
          [HVLM_no_charging_readiness_by_control_pilot]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 13
                    Mileage: 32310 km
                    Date: 2023.01.06
                    Time: 11:51:11
8516354 - Unknown Error Code
          P1CC3 00 [108] - -
          [HVLM_vehicle_to_grid_processing_timeout]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 4
                    Reset counter: 31
                    Mileage: 29091 km
                    Date: 2022.11.06
                    Time: 14:11:44
2232399 - No Communications with Front Sensor Package for Driver Assist. Systems
          U10E0 00 [040] - -
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 36
                    Mileage: 30570 km
                    Date: 2022.12.10
                    Time: 04:57:25
8515586 - Databus
          U1121 00 [108] - Missing Message
          [HVLM_occ_01_timeout]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 6
                    Mileage: 31129 km
                    Date: 2022.12.22
                    Time: 13:20:59
8515670 - Unknown Error Code
          B17E0 F0 [108] - Unknown Error Elaboration
          [HVLM_plug_not_locked]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 105
                    Reset counter: 30
                    Mileage: 25723 km
                    Date: 2022.09.30
                    Time: 15:02:49
8516406 - Unknown Error Code
          C1249 F6 [046] - Unknown Error Elaboration
          [HVLMSF_error_plug_locking_status_not_locked]
             Freeze Frame:
                    Fault Priority: 4
                    Reset counter: 40
                    Mileage: 25717 km
                    Date: 2022.09.30
                    Time: 11:43:48
2498823 - Application Server 1 for System 2 Java
          U1662 00 [044] - Internal Malfunction
          [Application_server_1_system_2_Java_internal_malfunction_vlan]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 253
                    Reset counter: 40
                    Mileage: 25968 km
                    Date: 2022.10.01
                    Time: 15:15:39
2498824 - Ethernet Application Server 3 for System 1 Infotainment
          U1663 00 [044] - No Communication
          [Application_server_3_system_1_infotainment_no_communication_vlan]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 29
                    Mileage: 35726 km
                    Date: 2023.02.23
                    Time: 12:40:17
Address 23: Brake Booster (J539)       Labels: None
   Part No SW: 1EA 909 059 N    HW: 1EA 909 059
   Component: EBB-ZF-Gen1   H28 0275
   Serial number:                 Dataset Number: V03935344BQ 0001
   Coding: 189E22AC003B183F443C00E620DF2020202020202021212121000404040404040404848484840008001000
   ASAM Dataset: EV_BrakeBoostZFMEB 012139
   ROD: EV_BrakeBoostZFMEB_012_VWE3.rod
   VCID: 45D75103F521FB227CD-8010 SFD
1 Fault Found:
2101863 - Combination / Chassis CAN Bus (SAE Bus D)
          U0056 00 [040] - Performance
          [MSG_DATA_BUS_0_GLOBAL_TIMEOUT]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 23
                    Mileage: 36155 km
                    Date: 2023.04.06
                    Time: 13:23:24
Address 2B: Steer. Col. Lock (J764)       Labels:| 1EA-905-861.clb
   Part No SW: 1EA 905 861     HW: 2Q0 905 861 B
   Component: ELV-MEB       H09 0040
   Serial number: 21000172549004 Dataset Number: V03935308NF 0001
   Coding: 8800000000000000
   Shop #: WSC 31000 074 00316
   ASAM Dataset: EV_ELVMarqMQBA0 002004
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 74B1DCC7EE3B32AA1B3-8020
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 2Q0 907 686 E    HW: 2Q0 907 686 E
   Component: HRE_Master    H25 0284
   Serial number: 14520010396036  Dataset Number: V03935345FN 0001
   Coding: 6A954750
   ASAM Dataset: EV_HREntryHellaGen3Mstr 001015
   ROD: EV_HREntryHellaGen3Mstr_VW38.rod
   Lane change assistance control module 2:
   Subsystem 1 - Part No SW: 2Q0 907 685 E    HW: 2Q0 907 685 E
   Component: HRE_Slave      H25 0284
   Serial number: 14520010287163
1 Fault Found:
2236437 - Databus
          U1123 00 [040] - Received Error Message
          [databus error value received - Parkhilfe_04 - APSOPS_PaCo_MainState]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 29
                    Mileage: 35779 km
                    Date: 2023.02.24
                    Time: 09:34:03
Address 42: Door Elect, Driver (J386)       Labels:* None
   Part No SW: 1EB 959 593     HW: 1EB 959 593
   Component: TSG FS003 0636
   Serial number: YE007UFA03799 Dataset Number: V03935354FR 0001
   Coding: 003F1120D000048001001000
   ASAM Dataset: EV_DCU3DriveSideMAXHKLO 001002
   ROD: EV_DCU3DriveSideMAXHKLO_VWE3.rod
   VCID: 55F7814305814BA20CD-8000
   Rear Driver Side Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 812 G    HW: 5Q4 959 812 G
   Component: Fond FHSG DRV  010 0004
   Serial number: 00000000000118963306
Address 44: Steering Assist (J500)       Labels:* None
   Part No SW: 1EA 907 144 AG    HW: 1EA 907 144 H
   Component: BASGEN1MQB37  246 5024
   Serial number: 00363031 Dataset Number: V03935350ZL 0001
   Coding: 0000000000000201000002010100010000000100010102
   ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 78A9E8F7F25356CA37B-802C
Address 51: Electric Drive (J841)       Labels: 1EA-907-121.clb
   Part No SW: 1EA 907 121 C    HW: 1EA 907 121 C
   Component: MEB PSM       H09 6035
   Serial number: VES_N4000573046 Dataset Number: V03935328UF 0001
   ASAM Dataset: EV_DMCM15000F11EA907121C 001009
   ROD: EV_DMCM15000F11EA907121C_VWE3.rod
   VCID: 2E050EAF4097587AAD7-807A
No ASAM data for: "EV_DMCM15000F11EA907121C" (SKE3)
Address 52: Door Elect, Pass. (J387)       Labels:* None
   Part No SW: 1EB 959 592     HW: 1EB 959 592
   Component: TSG BFS003 0636
   Serial number: YE007UFA0507A Dataset Number: V03935354FS 0001
   Coding: 003F1120D000048001801000
   ASAM Dataset: EV_DCU3PasseSideMAXHKLO 001002
   ROD: EV_DCU3PasseSideMAXHKLO_VWE3.rod
   VCID: 7F5B03EBD77D61F2761-802A
   Rear Passenger Door Control Module:
   Subsystem 1 - Part No SW: 5Q4 959 811 G    HW: 5Q4 959 811 G
   Component: Fond FHSG PSG  010 0004
   Serial number: 00000000000118965749
1 Fault Found:
196663 - Motor for Window Regulator
          B1487 4B [008] - Over Temperature
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 48
                    Mileage: 33470 km
                    Date: 2023.01.27
                    Time: 19:21:55
Address 5F: Information Electr. (J794)       Labels:* None
   Part No SW: 5LA 035 820 C    HW: 5LA 035 820 A
   Component: IC3-SF--EU    H20 0795
   Dataset Number: V03935341JW 0001
   Coding: 33157030000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 001001
   ROD: EV_MUICASSAFEPart_001_VWE3.rod
   VCID: 372B2BCBBFCD99B2FE1-8062 SFD
   Display and control head 1 for information electronics:
   Subsystem 1 - Part No SW: 5LA 919 606     HW: 5LA 919 606
   Component: ABT_W_13       H07 0108
   Serial number: BHB00123062104350151
1 Fault Found:
6179 - Display Module 1 for Multimedia System
          B1297 F6 [044] - Cable for Video Signal; Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Reset counter: 40
                    Mileage: 30937 km
                    Date: 2022.12.16
                    Time: 12:59:58
Address 69: Trailer (J345)       Labels:| 5H0-907-383.clb
   Part No SW: 5H2 907 383 B    HW: 5H2 907 383
   Component: Anhaenger     H10 0057
   Serial number: 000000000005795 Dataset Number: V03935302HN 0001
   Coding: 0100000202001400
   ASAM Dataset: EV_TrailFunctGener3Hella 001012
   ROD: EV_TrailFunctGener3Hella_VW27.rod
   VCID: 2F3B13AB479D5172A61-807A
Address 6C: Back-up Cam. (J928)       Labels:* None
   Part No SW: 1EA 907 556 G    HW: 5WA 907 556 C
   Component: TV eEntry     H17 0154
   Serial number: FZ6ESP280521000 Dataset Number: V03935345JV 0001
   Coding: 030331009C3000
   ASAM Dataset: EV_CamSysTVFicosMEB 006005
   ROD: EV_CamSysTVFicosMEB.rod
   VCID: 3E253EEF90F7A8FA3D7-806A
   Subsystem 1 - Part No SW: *              HW: *
   Component:
   Serial number:
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 10A 035 284 F    HW: 10A 035 284
   Component: OCUGen4       H17 0442
   Serial number: 0000000106VITDA Dataset Number: V03935349UW 0001
   Coding: 03310010106880008005460000000000
   ASAM Dataset: EV_OCUGen4 001034
   ROD: EV_OCUGen4.rod
   VCID: 1E65DE6F3037C8FA1D7-804A SFD
1 Fault Found:
1375744 - Secure Onboard Communication
          U14FE 00 [047] - Signature Verification Failed
             Freeze Frame:
                    Fault Priority: 1
                    Mileage: 25717 km
                    Date: 2022.09.30
                    Time: 11:36:57
Address 8C: HV Battery (J840)       Labels: 0Z1-915-184.clb
   Part No SW: 0Z1 915 184 F    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 007 0920
   Serial number: 000000080621090 Dataset Number: V03935352BL 0001 CVN: EADD3EDD0000000037CBCE7B3DFBA09F3DFBA09F
   ASAM Dataset: EV_BMCeVWBSMEB 001012
   ROD: EV_BMCeVWBSMEB_001.rod
   VCID: 3D2739E39DF1B3E224D-8068
   Cell module control module 1:
   Subsystem 1 - Part No SW: 0Z1 915 140 BD    HW: 0Z1 915 140 BC
   Component: SX6  X74  CMC  005 0900
   Serial number: 00000031052108010164
   Cell module control module 5:
   Subsystem 2 - Part No SW: 0Z1 915 140 E    HW: 0Z1 915 140 D
   Serial number: 00000008062108020564
   Cell module control module 9:
   Subsystem 3 - Part No SW: 0Z1 915 140 E    HW: 0Z1 915 140 D
   Serial number: 00000008062108020543
   Coolant heating:
   Subsystem 4 - Part No SW: 1EA 963 231     HW: 1EA 963 231
   Component: J848 HV-PTC    H03 0500
   Serial number: CH211543014403000015
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 1EA 980 654 J    HW: 1EA 980 654
   Component: MEB MFK 4.1   H03 5230
   Dataset Number: V03935349TV 0001
   Coding: 0208302E1F9108E0062420000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001053
   ROD: EV_MFK41ValeoMEB_VWE3.rod
   VCID: 41DF4513E109D702405-8014
8 Faults Found:
1124496 - Databus
          U1123 00 [044] - Received Error Message
          [ACC_18_ACC_Status_ACC_reversibel_ERROR]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 39
                    Reset counter: 30
                    Mileage: 29877 km
                    Date: 2022.11.22
                    Time: 05:14:05
1124198 - Development code 1
          B2F01 00 [044] - -
          [VZF_Init]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 6
                    Mileage: 32573 km
                    Date: 2023.01.11
                    Time: 18:13:06
1124633 - Databus
          [KLR_01_KLR_Touchintensitaet_2_ERROR]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 28
                    Mileage: 29817 km
                    Date: 2022.11.21
                    Time: 16:04:31
1124632 - Databus
          [KLR_01_KLR_Touchintensitaet_1_ERROR]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 28
                    Mileage: 29817 km
                    Date: 2022.11.21
                    Time: 16:04:31
1124634 - Databus
          [KLR_01_KLR_Touchintensitaet_3_ERROR]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 28
                    Mileage: 29817 km
                    Date: 2022.11.21
                    Time: 16:04:31
1124631 - Databus
          [KLR_01_KLR_Touchauswertung_ERROR]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 28
                    Mileage: 29817 km
                    Date: 2022.11.21
                    Time: 16:04:31
1124755 - Databus
          U1121 00 [044] - Missing Message
          [POS_MM_06_Status_TIMEOUT]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 39
                    Mileage: 25968 km
                    Date: 2022.10.01
                    Time: 15:15:29
1126420 - Databus
          [FAS_Anzeigen_01_TIMEOUT]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 26
                    Mileage: 35779 km
                    Date: 2023.02.24
                    Time: 09:33:57
Address C0: Act. for Ext. Noise (J943)       Labels: 1EA-035-335.clb
   Part No SW: 5LA 035 335     HW: 1EA 035 335
   Component: E_SOUND_SG    H05 0003
   Serial number: JTK072240621812
   ASAM Dataset: EV_ESoundMEBHarma 004011
   ROD: EV_ESoundMEBHarma.rod
   VCID: 75B7E1C3E5412BA22CD-8020
Address C6: Batt. Chrg. (J1050)       Labels:| 1EA-915-684.clb
   Part No SW: 1EA 915 684 BG    HW: 1EA 915 684 BF
   Component: HV_CHARGER    H52 0013
   Serial number: 92832UDU0003D   Dataset Number: V03935328RP 0001
   Coding: 1080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002010
   ROD: EV_OCCXPhase1KLOMEB01B.rod
   VCID: 015F8513A1891702005-8054
9 Faults Found:
4194316 - Intermediate Circuit Voltage Warning
          P195C 00 [032] - -
          [Over_voltage_shutoff_dc_link_rail3_hint]
1061380 - Function Restriction due to
          C1249 F4 [032] - Too Many Wake-Up Requests in Charging Infrastructure
3276854 - Intelligent Charging Function
          U15BF 00 [096] - Communications Error
          [SCC_TCP_ERROR]
3280899 - Charging Station
          B1AD0 F0 [109] - Identification Failed
          [ETHTRCV_30_AR7000_SLAC_STEP_3_PARAM_REQ_Timeout]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 30
                    Reset counter: 40
                    Mileage: 23937 km
                    Date: 2022.08.21
                    Time: 20:52:42
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Frequency: 999 Hz
                    Control voltage: 6352.0 mV
                    Duty cycle: 14.4 %
                    Activation charge cover lock charge socket A: not requested
                    Lock for high-voltage charging connector: locked
                    Status connect. recognition: detected
                    Charge socket temperature sensor AC: 30.0  C
                    Temperature sensor 1: resistance value: 1072 Ohm
                    DID 15E2: 23.0  C
                    DID 081C: 148 W
                    DID 081D: 143 W
                    DID 081E: 151 W
                    DID 0286: 12.3 V
                    DID 497C: not active
                    DID 537A: 14.4 V
                    DID 1525: 3222 mV
                    DID 4219: High voltage power off recognized
                    DID 5372: 23.0  C
                    No. of lockings: 784
                    No. of connections: 0
                    Number of successful charging connector locks: 360
                    Wake-up counter: contact (proximity): 1
                    Wake-up counter: Control Pilot: 2
                    Charging standard abort: status: not active
                    Loading plan: status: Not available
                    Price/performance table: status: Not available
                    Transport Layer Security (TLS) status communication: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 1
                    DID 1033: SLAC_failed
                    DID 1038: no_description
                    DID 1039: supported
                    Target HV charge current: 0.0 A
                    Powerline communication: charging process status: Standby
5242881 - Secure Onboard Communication
          U14FE 00 [096] - Signature Verification Failed
13705218 - Databus
          U1121 00 [046] - Missing Message
          [HVK_01_TimeOut]
             Freeze Frame:
                    Fault Priority: 6
                    Reset counter: 40
                    Mileage: 23834 km
                    Date: 2022.08.17
                    Time: 07:52:58
                    DID 0286: Write only channel V
                    DID 1DA0: Write only channel
                    DID 1DAC: Write only channel
                    Reserved: Write only channel
                    Activation charge cover lock charge socket A: Write only channel
                    Lock for high-voltage charging connector: Write only channel
                    Status connect. recognition: Write only channel
                    Charge socket temperature sensor AC: Write only channel  C
                    Temperature sensor 1: resistance value: Write only channel Ohm
                    DID 15E2: Write only channel
                    DID 497C: Write only channel
                    DID 537A: Write only channel
                    DID 4219: Write only channel
                    DID 5372: Write only channel
14746211 - Battery Charger; Primary Voltage L2
          P31EB 00 [096] - Too Low
14750979 - Unknown Error Code
          P1CF4 00 [096] - -
          [Plug_locking_blocked]
14750980 - Unknown Error Code
          P1CF5 00 [104] - -
          [Plug_locking_error]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 22
                    Mileage: 36687 km
                    Date: 2023.04.30
                    Time: 12:34:56
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Lock for high-voltage charging connector: not locked
                    Temperature sensor 1: resistance value: 1082 Ohm
                    DID 15E2: 11.0  C
                    Sensor 1: 2.0 V
                    Sensor 2: 2.0 V
                    Sensor 3: 5.7 V
                    DID 0286: 12.5 V
                    DID 537A: 14.4 V
                    DID 5372: 10.0  C
Address D6: Light Ctrl Left 2 (A31)       Labels: 7PP-941-572.clb
   Part No SW: 992 941 572 AD    HW: 992 941 572 A
   Component: LED1L         H08 9102
   ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
   ROD: EV_LLPGen3LKEBODPO68X_001_VW27.rod
   VCID: 6597B18355E1DB229CD-8030
Address D7: Light Ctrl Right 2 (A27)       Labels: 7PP-941-572.clb
   Component: LED1R         H08 9102
   ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
Address 8105: DC/DC Converter 12V (A19)       Labels: 1EA-907-190.clb
   Part No SW: 1EA 907 190 G    HW: 1EA 907 190 G
   Component: DCDC Gen4H13 1142
   Revision: 00H13000
   ASAM Dataset: EV_DCDC10030111EA907190G 001022
   ROD: EV_DCDC10030111EA907190G.rod
   VCID: 382928F7B2D396CAF7B-806C
3 Faults Found:
0110 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [040] - -
          [Lost Communication with ECM/PCM]
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 4
                    Mileage: 33810 km
                    Date: 2023.01.30
                    Time: 05:23:05
                    DC/DC Converter traction power supply: 3.53 V
                    DC/DC Converter controlled output current terminal 30: 12.480 V
                    DC/DC converter: voltage 1 active rectifier: 9.092 V
                    DC/DC converter: voltage 2 active rectifier: 9.037 V
                    DC/DC converter: transformer current 1: 0.000 A
                    DC/DC converter: transformer current 2: 0.000 A
                    DCDC temperature sensor 1: 16.59  C
                    DCDC temperature sensor 2: 14.13  C
                    DC/DC converter: operating mode output path 1: rbe_CmnGlb_DcdcMod_Stb_e
                    DC/DC converter: operating mode output path 1-Test_Program_Rbe Asw Dcdc Sym Enum rbe Cmn Glb St Dcdc Mod UBYTE: 1
0134 - No Communication with Engine Control Module (SAE ECM/PCM)
          U0100 00 [032] - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 112
0092 - Control Module Improper Shut Down
          U3001 00 [032] - -
          [Control Module Improper Shutdown]
             Freeze Frame:
                    Fault Priority: 2
Address 811E: Burglary Protection FL (J518)       Labels: 5WA-962-133.clb
   Part No SW: 5WA 962 133 D    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
Address 811F: Burglary Protection FR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: 5WA-962-133.clb
   ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: V04-007-003.clb
   Part No: V04 007 003 EA
   Component: ICAS1 Sys_Ada 0123
   Dataset Number: V03935341JD 0001
   ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
   ROD: EV_AppServe1Syste1ICAS1.rod
   VCID: 6A8DC2BFBCFFF45AB1F-803E SFD
Address 8124: App server 1 system 2 Java (SWC5)       Labels: V04-007-003.clb
   Part No: V04 007 003 EB
   Component: ICAS1 Sys_Jav 0123
   Dataset Number: V03935332P  0001
   ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
   ROD: EV_AppServe1Syste2ICAS1.rod
   VCID: 6B83C7BBB305ED52CA9-803E SFD
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:* V04-007-003.clb
   Part No: V04 007 003 CM
   Component: IC3-IVI-D-EU  0795
   Dataset Number: V03935350CM 0001
   ASAM Dataset: EV_MUICASIVIPart 002007
   ROD: EV_MUICASIVIPart_002_VWE3.rod
   VCID: 74B1DCC7EE3B32AA1B3-8020 SFD
1 Fault Found:
0021 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [Function restriction via shutoff stage Q2]
             Freeze Frame:
                    Fault Priority: 9
                    Fault Frequency: 3
                    Reset counter: 29
                    Mileage: 35803 km
                    Date: 2023.03.27
                    Time: 06:00:44
                    Voltage terminal 30: 11.3 V
Address C002: SW Cluster Embedded (SWC2)       Labels: V04-007-003.clb
   Part No: V04 007 003 EC
   Component: ICAS1 SWCL_Em 0123
   Dataset Number: V03935350BY 0001
   ASAM Dataset: EV_SWCLEmbed1ICAS1 005001
   ROD: EV_SWCLEmbed1ICAS1_VWE3.rod
   VCID: 6C81C4A7B60BEA6AC33-8038 SFD
1 Fault Found:
13706049 - Databus
          [WLA_Blindheit received error value]
Address C003: SW Cluster Housekeeping (SWC3)       Labels: V04-007-003.clb
   Part No: V04 007 003 ED
   Component: ICAS1 SWCL_HK 0123
   ASAM Dataset: EV_SWCLHouse1ICAS1 005001
   ROD: EV_SWCLHouse1ICAS1.rod
   VCID: 6D87C9A38D11E362D4D-8038 SFD
End----(Elapsed Time: 02:38, VBatt start/end: 15.1V/15.2V. VIgn 0.0V)------
I've not had any luck coding the enyaq with VCDS, I had to use OBD eleven to make any changes 😞
  • 1 year later...
What bytes did you change for that?
you can't do it any more, they have locked all the modules down with security software now
With OBD11 I can. I did already, but only ASR off OR ESC sport, not both.
I now have a 2024 car and it is locked down, you can change nothing. OBD11 say they are workign on an update to bypass this but they stillsay it will be ready by "end of 2024" :-(
  • 10 months later...
Hi everyone, I'm trying to enable High Beam Assist on my Skoda Enyaq (Software 3.8) using OBDeleven NextGen. Even with the bonnet open (red icon in dashboard) and ignition on, modules 09 (Central Electrics) and A5 (Driver Assistance) are still showing as 'Not Reachable'. I've tried scanning several times, but they remain greyed out. Is this an SFD2 restriction on the 3.8 software? Any workarounds?
ESC coding on the Enyaq can offer some interesting customization options, but it’s important to approach it carefully. Changes to stability and traction systems can impact safety if not done correctly. Consulting detailed guides or working with someone experienced in VW Group coding ensures that adjustments enhance your driving experience without compromising vehicle control.
