Fabia Oil Loss
The Fabia manual indicates that the engine can 'drink' (probably the best word for it) up to half a litre of oil for every 600 miles it does.
:confused: I'm assuming that this is a very high figure but does anyone know what is 'normal'?
And, I can't find any indication of the oil quantity represented by the thatched area on the dipstick.
:confused: Does any one know how much oil is represented by the thatched area (that is, if it's one quarter down, is that half a litre needed or what?)?
The Fabia manual indicates that the engine can 'drink' (probably the best word for it) up to half a litre of oil for every 600 miles it does?
Thats nothing, the manual for my CTR says that upto 1 litre per 600 miles is considered normal! :eek: Luckily mine only uses about 1 litre per 10k miles.
Don't know what normal for the fabia though, still got 10 weeks to wait for mine :o
the manual for the Mazda RX8 says check and top up every second fuel tank fill up iirc , oil is injected into the combustion chamber to lubricate the rotor tips , this car uses a large amount of oil
The manual for my CTR does actually say to check the oil every time you fill with petrol, i just check mine every week or 2. :cool:
1 litre fills the car from the bottom of the hatched area to the top on the dipstick.
1 litre per 600 miles (approx 1000km) is permissable.
engines will also use more oil when new. You should find oil usage drops as the engines wears in.
I used over a litre & a half below 2000miles then nothing since :thumbup:
