Trickle charging Octavia Mk 2 vRS
Hi all, new on here. My '06 vRS estate is now only used for occasional longer trips following purchase of a Citigo. I'm concerned about battery depletion and would like to leave the battery on permanent trickle charge as I do with my motorcycle.
- Can anyone recommend the most suitable trickle charger for this type of battery?
- Do I need to disconnect battery negative before charging, or can I just connect the charger across the battery?
- Could I use the aux power socket in the boot for trickle charging? Obviously depends how it's connected.
Thanks for any input!
